Moeed said:Can you data log it?
the datalog showed nothing. the analog out voltage never got close to 5V which means it should nto have fuel cut. any thoughts?
Bigg Tim said:So it ran fine before you did the xtra injectors and when you hook them up it runs like ass? IF there are no values in the F2 map then there is NO WAY you are adding fuel via those xtra injectors if hooked up right.
You have the positive of the xtra injectors to the battery and the negative to the gray MPI wire right? On mine, I just ran the positve directly to teh positive terminal of the battery.
mspHtown said:Yes, i do have the positive to the battery and the negative to the gray MPI wire.
igdrasil said:you will have to test them out of the intake...some will stuck open
Take them out, still connected to the fuel, and activate them thru the map and see if they open, then shut them off same way and see if they shut off.
mspHtown said:i know they are firing properly. i dumped a ton of fuel while idling to see if they actually worked. and they did.
igdrasil said:then you may have a bad 02 sensor. wired incorrecly or open circuits
igdrasil said:then u are pushing too much fuel.
Try this...eveytime you do a change in the map, close the software and open it again...see if the changes got saved.
Moeed said:So what number do you have in your map?
mspHtown said:I dont know how this is confusing.
Ran the car. no fuel cut. no bucking. extra injectors are not activated(fuse is out).
Pulled over. put the fuse in (extra injectors activated). added fuel with teh extra injectors at idle to make sure they were working. The a/f ratio richened up thus confirming they were working. I went back to the F2 map and cleared out all of the values (so now there were 0's in every cell). The fuse was still in (injectors activated) but they were not firing any fuel at all. I dowloaded to the tuner to make sure the tuner changed as well as the software. I also closed the software and reopened it to make sure everything had been saved.
Start driving the car and it hits fuel cut, bucks, and drives like complete s***.
Pulled back over, took the fuse out (extra injectors are not activated anymore) and the car ran normal again.
srry to sound irritated but you would be the same in my shoes.
igdrasil said:We may be missing something....
Do you have a screenshot of your mpi? Are you sure F2 is your extra injectors?????
mspHtown said:not to be a prick but i have had the mpi for over a year. i have provided as much details as possible about the problem. obviously i know which map is my auxiliary injector map. has anyone ever had this problem or heard anything about it.
xelderx said:Blthlt and I too ka look at my setup briefly yesterday. We are going to recheck my wiring and see how mine is hooked up. This O2/MAF wiring difference for NA is news to me. I'm hoping we can sort it out as I've had the MPI for almost 2 years now and I haven't been able to get anything out of it.
Deathspeed said:Ok i was wondering where i can get the cable to hook up the mpi to a laptop and about how much it will run me
