islander81
- mazdaspeed protege 2003.5
so basically just change the stock bypass valve with that turbo xs one like cullen at ********** has thats basically my setup if ya'll seen his car pics.
I bought mine from a forum member and he ran the yellow one with 10psi. I bought a kit from Forge with all the springs. I can't remember for sure, but I think I am running the green one with both shims in. I spike to about 10 and settle at 8-8.5. I do still get a small amount of compresser surge, but it is very little.msfamilia said:May I know what color of spring did you guy's Forge BOV come preloaded with?
msfamilia said:I just installed mine too.
However, the springs in the springs kit that came with it have all discolored and I couldn't tell which is yellow and which is green, or wrose that they are both yellow.
So all I got is turkey which is even heavier than when using the stock BPV.
Does anyone have a green spring that they would want to sell me?
Jenn said:I've got the same valve I believe. Only thing about mine is when I come to a stop, it gets REALLY rich, then the revs drop REALLY low, then come back up.
Like less than 10 on the A/F gauge...but it doesn't stall out.
tallrd said:I'm in need of some advice from you who have "been there done that."
I'm currently running the dual set up and need some informed opinions (as opposed to guesses please).
I have my Greddy RS venting to atmosphere and my stock bpv recirculating to my Injen from the hot pipe. The original purpose of this was to prevent stalling when the pressure got released. I've since relocated my MAF to just before the throttle body to aleviate this problem. My problem is that my system won't hold boost. I have a mbc and a boost guage both of which are hooked up correctly, but no matter how much I turn it up it won't go more than peaking at 10psi and settling at 7psi.
A) Do I still need that bpv on the hot pipe recirculating into the Injen inlet?
B) If so, would getting a forge bpv help me get that boost level under control.
C) How do I otherwise check for boost leaks in the system?
Dugg E Fresh said:I can't give you a "yay." But I can give you my opinion (which ain't worth a s***, here nor there). I have heard the stock BPVs are s*** anyway and prone to leak, that may be some of the problem. I would only assume that with your MAF relocated, it should read correctly after the BOV vents to the atmosphere and not stall out on you. As long as your BOV is operating correctly, you should be able to hold your boost level.
Just my .02
If you have the BOV venting air BEFORE the MAF sees it, you will be fine w/out recirc'ing it. The only reason you have problems is when venting metered (already seen by the MAF) air.tallrd said:that's what my gut is telling me, but these cars aren't always what they seem and I'm not a mechanical engineer.
can I get anyone to give me a "yay" or "nay" for or against what we're thinking?
That is what I would do. All else fails, hook it back up. At least if you take off the BPV, and you still aren't able to hold the boost like you would like, you know that the stock POS is not the culprit.tallrd said:...meaning I should remove the bpv all together?
