nautical2086
- 1999 Mazda Protege ES
I'm currently working on my bumper and reglassing the broken areas and stuff. Do I need the gel coating for paint? Or after im done glassing n stuff just sand it and paint?
ForceFed said:You dont need a gel coat but you will need to prep ,orime and prep again before paint.
So to answer your question...No Gel coat needed.
YES...the "O" is next to the "P"...And I suck at typing..Prep by making smooth...then prime...and yes you have to prep the primer by sanding it smooth as well...from there your body guy should take over and seal the part before painting it.HorsepowerFreak said:I think he meant 'Prime".
Gelcoat works as a primer...
