anyone have pictures of a mazda6, with the BOSE sound system, with an aftermarket head unit?
search for the metra kit. thats what you need.
Anyone know what happened to Sylfex's AuxMod Advanced? Or could point me in the direction of some similar product to connect a phone to my Speed6 via the headphone jack?
I almost didn't buy my Mazda6 because I had read about how difficult it is to integrate an iPod - and I LIVE by my iPod. Luckily, I discovered this little device and took a chance that it would work for me - and it did!
http://www.alpine-usa.com/product/view/ex-10/
http://www.crutchfield.com/p_500EX101/Alpine-eX-10.html?tp=120
This Alpine eX-10 is a great alternative to the metra dash kits or aux-mods - I'll post pics of the install once I get it looking clean. For now I'm just enjoying my music.
A little late to reply but in case others have the same question I'll respond. Once you remove the 4 channel amp under the seat, there will be no signal to the subwoofer amp in the trunk. The best approach is to grab the stereo signal from the harness under the seat and run new wires for everything else. In theory, you could reuse the factory speaker wiring by running speaker wire back to the same harness under the seat. It might save you time but I've always upgraded the wiring when I increase the power. As for amp selection, you can use any number of amps. It all depends on preference and how much power you are looking for. Typical 5 channel amps don't have high powered subwoofer channels so they are usually only good for a single small sub. If you're looking for serious bass, you'll probably end up with two separate amps.New member here and thanks for allowing my participation in this valuable forum.
I read Chuyler1 excellent post regarding bose upgrade options.
I am still a little unclear as to speaker wiring.
I plan on upgrading both the bose factory amps and upgrading all the speakers and leaving the HU In my 2005 6 gt wagon.
Will I have to run new speaker wire or can I tap/ use the existing .
Also is my thinking right by using a 4 channel amp for passenger comp. and a seperate 1 channel for sub ?
Or
Could I use just one 5 Channel .
Any thoughts on equipment choice ? I dont want loud just clean.
Will the old factory amp remain in place with its harness connected or will I just tap the harness and remove the factory amp .
Many thanks
Yeah, that thing is just an FM transmitter which is why I didn't bother adding it to the original post. It does have an aux output though, so you could theoretically connect it to any one of the options listed...but why bother when you can just hook up the iPod directly and save yourself some dough.Isn't this just a fancy FM transmitter?
You'll also need a wiring kit. Follow the instructions linked in the original post on how to run a power cable from the battery and connect the input signal from the factory subwoofer wiring harness.So if i have a pair of subs i want to hook up to the stock bose system all i would need to do is get an amplifier to power the subs and i would be set?
