- 03 mazda protege 5 automatic
just had the ect replaced, and the code cleared/CEL went off. after a drive around the block, i restarted the car and then the CEL came back on (flashing, later steady).
p0300 showed up again.
uncle used his scanner, and then the CEL was off.
drove about 16 miles on the freeway with AC on 2-3 with no problems. stopped at a few stores, and then
i notice the engine temp meter is rising slowly to the top. blast the heater and it drops and stays at roughly a little higher than half.
made it home; couldnt smell coolant and saw no smoke or steam (from hood or exhaust) when driving.
ive heard that coolant should be flushed when ect sensor is replaced...is that wrong?
i ask because the coolant was not flushed.
