Ticking noise: I hear the ticking noise only when the is not warmed up. I did speak to the dealer and was told that the noise is normal and some are louder then others. It's coming for the value lifters. You can also, get the ticking noise, from the fuel injectors. To check where the noise is coming from, you would need a long screwdriver. Take the tip of the screwdriver and place it on the fuel line to the injector, the other to you ear. If you hear ticking, then it's your fuel injectors and that it normal. (engine must be on)lolol..... If not, take the screwdriver to the value cover and your ear, and if you hear ticking, it's you lifter. (That is also normal, if you are no burning oil.)
The best thing you can do is to take it to your dealer and have them check if out. If they say, it's normal and have then, state it on your service receipt, and records. (drunk)
