DarthNewky
- 260th MP3, Blue Mica
Ok, about 2 weeks ago I hydro'd my car. Came around a corner and the road was flooded, before I realized it i was in the water. Sucked it up the CAI at low speed.
Towed it home, drained the oil(no water seen) and all the water from the cylinders and intake mainifold. Let it air dry and put everything back together. Worked fine didn't notice any ticks or anything. Did smoke a lot at first but figured that was just burning off a lot of water. Don't recall it smoking much after that.
Drove about 120 miles home from parents. Bought Fram ToughGuard 6x Oil Filter and Pennzoil High Milage vehicle 10w40 special from Autozone. Penzoil also has Active Cleansing agents. Did a proper oil change.
After oil change noticed extreme smoke coming out of car, not positive if it happened prior or not. But definitly noticed it after replacing the oil.
Visual inspection, dropped exhaust header, and its covered in oil inside
Looked at valves through exhaust ports, and they look oil covered
All 4 spark plugs are burnt white
Compression test
Pass Side to Driver Side Cylinders
Dry/Wet
Cyl 1 160/170
Cyl 2 185/200
Cyl 3 180/190
Cyl 4 180/200
So all seem to be around the same except Cyl 1
Took out schrader valve in compression kit and did a cheap leak down on Cyl 1
I can hear air coming out of the intake.
Remove Radiator cap, no bubbles
Listen at tailpipe, no hissing
Open Oil Cap, air switches to this, cover switches back to intake
Open Dip stick, air switch here, place it back and returns to Intake.
Any help would be greatly appreciated. I have video's of the Compression test, did this so I could see what the gauge was doing while I returned to the front of the car. Also have pictures of exhaust. Let me know if they would be helpful.
Basically trying to figure the most cost effective thing to do. Engine is 2500 shy of 200k. This is my daily driver and my only vehicle I have. So kinda need something I can do over a weekend.
My thoughts are Valve seals are gone. That I will need a Head Gasket, valve gasket and rebuilt Head.
Compression test
Dry/Wet
Cyl 1 160/170
Cyl 2 185/200
Cyl 3 180/190
Cyl 4 180/200
