2002 Protege5 2.0L. 99,911 miles.
Recently the electrical system has been acting up. The head lights & interior lights & engine idle are all surging together; The lights would go dim and then brighten up in sink with the engine idle. I used my DVOM to measure the voltage at the Battery: The results are 12.5v up to 18.3v, up & down like that. I thought it was a sign of a failing Alternator.
[The PCM recorded a DTC of P1632- Generator Voltage to PCM below 8.0v]
I ordered an Alternator from Maniac Electric Motors. Friday Night I Removed and Replaced the Alternator and Battery. No help. The same problem was happening.
The issue seems to subside when the heater fan is switched on. It also sounds like the A/C Compressor is cycling on/off when the Heater fan is turned on.
I read more about the DTC-1632 & that there is not sufficient voltage to PCM through wt/gr wire from fuse box.
Does any one have any further information about this issue? This is puzzling to me. I have been an Automotive Technician for 2.5 years now, and unfortunately electrical has never been a strong point.
Where is the PCM located in this car?(I don't have ALLDATA on my home computer) Is there a pin-point test available for DTC-P1632?
Can any of you guys point me in the right direction as to what may be the cause of this issue?
Thanks in advance!!!
