see ure not keeping up with the commanded either. Your running about 11.0 in certain places. what are you mods and temps?
i dont get this car, some people are reporting commanded in the low 9s and your showing commanded in the low 10s.
Temp was about 45 F, only engine mod is Cobb SRI (till tax refund comes (nana))
And my commanded did drop down into the 9's, the grid is attatched to rpms so it's kinda hard to track it back. Does anyone know how to change what the grid snaps to?
Here's my logs. I'm basically stock except for MS CAI. But it seems that my AFR tracks the commanded pretty well when starting from a standstill (log 1). The second log was started from a roll in 2nd gear and they didn't track nearly as well. Both runs same day @ 70F.
Hope they help.
Well driver recieved my DH and based on quick runs, its off by about 1 point to lean. he didnt datalog anything, he was just staring at it and his uego. im going to send him over the software and hes gonna datalog and post here.
btw at idle is uego reads 14.7 14.8 and the dh reads 14.2-14.5
I don't think the dashhawk is "off" per se. It would actually be the Mazda OEM sensor that is off. All the dashhawk does is grab the data from the sensor. It might lose a .1 here or there due to signal loss, etc. But I doubt its a full 1.0 off from "actual" unless the sensor is actually 1.0 off.
Which I guess could point to a whole other host of problems if your ECU is asking for 9.0 AFR, but a faulty sensor is causing you not to be able to hit that number.
Drivers wideband is installed exactly according to AEMs instructions. it is 1 foot from the turbo.
i'm picking up my DH this afternoon and i'm scheduled to dyno tomorrow morning.
will post results.
figured i'd just chime in with my 2 cents.I don't think it will track exactly the same either since the stocker is right at the outlet of the turbo and the dyno probe is in the tailpipe... There will be differences in readings.
