I tried to address this earlier but the forum server appeared to die for a while.
I've not seen a Braille battery in use, but I understand the concept. Not a bad idea, IMO. BATCAP is also another one that does this small battery thing. I have, however, used lots of Optimas, both red and yellow (though no blue), and I love them all. Particularly, I find them to be near bullet-proof. Example: I had a Nissan stanza that liked to eat alternators for one reason or another. During one of its sessions of destruction, the voltage the alternator produced to the battery was a searing 20V+ The battery didn't care, and simply out-gassed a little bit as the internal pressure probably went a bit overboard. I quickly disconnected the alternator, and drove the car until the battery started to die from starvation. In a desparate attempt to get home, I reconnected the alternator, and got the battery ultra-charging again, and made it home with no other consequences. Of course I changed the alternator and no permanent damage observable through tests or through real-world use was detected from the battery. The only time I've managed to destroy one of these batteries was when I accidentally stuck one on a charger/start box, and left it on START instead of trickle charge. THAT killed it! LOL. Dumb me. Crazily enough, it actually didn't fail immediately after that. The battery terminals were distorted, the plastic warped..but I had to get home, so I connected my terminals of my car to it, and it started and ran! I quickly got to the parts store to buy another one (and was fully covered with a replacement one!)
Short version of what I recommend to you...Optimas are unstoppable.
Now grounding kits...Well I'll be frank about it, and say you can make your own for a few bucks using quality wire and crimp your own. But, if you can find a quality grounding kit cheaply, then why not? It isn't really a mod, its just a nice thing to do if you want to. When you have an upgraded sound system, it does come in handy (we call it the "Big 3" in the audio world.)
Thanks Fourthmeal!
I heard the Optimas are the best battery for the $, but there are the new lightweight CF Braille batteries, not totally sure about those. Anyone have suggestions?
I'm running stock electronics (+GPS, Dashhawk, and R7) and the car will be used in the winter in areas where it snows, so max amps is ideal -I think.
Another possibility I wondered about is using aftermarket grounding harnesses. Some people swear by it, I'm one of the cynics. Not sure if it would help with the battery issue. But can it actually improve MPG and HP over the long run? I read in another thread it was a temporary "high" and the ECU re-learns the condition. Haven't seen a single signature with someone claiming a Grounding kit... so I can't ask the question directly. Thanks in advance.
