cycoutMSP03.5
- 2003.5 Blazin' Yellow Mazdaspeed Protege
anybody have squeeky shocks in the back?? or is it just my fat ass?
later
ry
later
ry
my upper pillow mounts seem to be noisy, sounds like the clunk but it isntcycoutMSP03.5 said:anybody have squeeky shocks in the back?? or is it just my fat ass?
later
ry
later
ry
So i guess you have to actually remove the bushings? I sprayed mine with WD-40 and the squeak came back in a couple of days. Gotta do it again...kokioki said:I just fixed my rear squeak this past weekend... just jack the rear end, take out the bushings holdin the rear sway bar, lube the little bitches like a virgin on prom night (i used oil, but hear silicone grease is the way to go here), reinstall, and tighten like its goin outta style.
Fixed!
Amazing, I used wd-40 as a quick fix for a few days ( ended up being more like 6 weeks so far as I don't want the dealer touching my car!) and in no way did I say it was a "fix". But, here we are.kevducridr said:WD-40 will NOT be permanent solution even if you take them out. You need the specialized Silicone Grease that he mentioned above. You can get it at any autoparts store. (headbang)
WD-40 is a mild lubricant that will evaporate with heat and pressure.
later
ry
This happens to me too. When I get out of the car, it squeeks and creeks. But it seems as though it's coming from the location of the wheels or shocks rather than the bushings.kevducridr said:I think you got lucky on the WD-40 thing. (lol2) The squeek and heat are not coincidence. Regardless of latent outside temps, if I drive the car the rear bushings will squeek when I stop and get out. (doh) I will grease mine when I get some spare time.
If you can get the rear end of the car off the ground, it takes only 5-10 minutes to remove, grease and reinstall the bushings.
I have a squeeeeeek too it happened like 2 weeks after I went autocrossing and It sounds exactly like what you are discribing at first it sounded like it was my wheels then the front of the car but I now I had someone drive my car and it sounds like it's coming from the rear. Where are the bushings located??? I thought this was a common problem on MSP's not P5's.Newf said:yeah, its the bushings. The sound does kinda throw you off and make you think it's somewhere else. But, get under the car, and grab/pull/push your rear bumper while your there and you'll hear it.
get under car, look at big red sway bar with racing beat on it. You'll see two rubber things, with brackets around them, one on each side before the bend. ta da...bushings.Subghetto said:I have a squeeeeeek too it happened like 2 weeks after I went autocrossing and It sounds exactly like what you are discribing at first it sounded like it was my wheels then the front of the car but I now I had someone drive my car and it sounds like it's coming from the rear. Where are the bushings located??? I thought this was a common problem on MSP's not P5's.
Thanks (thumb), I thought the red racing beat sway bar was only on the MSP's I'am going to check tomorrow but I think mines black.Newf said:get under car, look at big red sway bar with racing beat on it. You'll see two rubber things, with brackets around them, one on each side before the bend. ta da...bushings.
