Okay, I have two type R subs (peak 1G and like 4 or 500 RMS per sub) I have a 600 watt amp (kenwood) going to both subs, the system hits hard, but after a lil bit OR if i turn it up to loud, then the amp like cuts out and I can only hear the speakers (not connected to the amp) and not the subs, unless I turn the sub down then when I turn it up, i am able to hit sometimes jsut as hard and other times I cant turn it up as loud other wise it will cut, if i keep doing it (where I turn the system down and stuff) then it starts to become choppy, meaning the subs will hit for like a couple seconds then cut out for a couple seconds, then keep doing it, unless I turn the system ALL the way down and it seems like the amps isnt holding the power. Now I was wondering if i bought another amp OR if a bought a capacitor, would this help the problem?? because I know the amp is underpowering the subs. Also before when I had my truck (before I totaled it and got my mazda) I had the same problem BUT i had a 760 watt Sony going to it, and it did not seem to cut out as bad, although it still did cut, and its embarrassing when it cuts out, please help. If I just hook my 760 watt amp up with the 600 watt amp to both the subs, will this kill the problem?!?!?!?!
