Car in question: 2009 Sport, MT, automatic climate control. According to the owner manual, when AUTO mode is turned on, A/C is turned on and the air is automatically directed to the windshield and feet area. I played with this a bit and it seemed that it is possible to turn the A/C off and still have the climate control operate in the AUTO mode. On the other hand, switching the direction of air flow did not seem to be possible - the AUTO mode would turn off. At least, it seemed to work that way until today.
A few hours ago as I was driving home through a very humid and somewhat cool air mass that has descended on Boston, I noticed that my windows were fogging up and upon closer inspection realized that the climate control decided to direct the warm air to my face, not the windshield. I played some more and it looked like the air flow direction (in AUTO mode) depends on the temperature setting: below 67 degrees the air blows in the driver's face, at the higher settings - somewhere around 69 - it is directed towards the windshield. When temperature is set between 67 and 69 - the controller seems to flip a coin. On one hand, if temperature is set at 66 degrees, it probably is hot outside and it sort of makes sense to direct the cool air into the cabin (not onto the windshield). On the other hand, this is not the behavior mentioned in the owner manual. Is it a feature, or a bug? Should I enjoy it, or run to the dealer and complain?
