DTC P0455- FUEL CAP REPLACEMENT
Applicable Models
Model Starting S/N Ending S/N Model Spec CX7 2007-2007 100057 128606 RX8 2006-2007 200001 208465 MX5 2006-2007 100001 125468 Related Category/Subcategory/Symptoms
ENGINE / FUEL / IMPROPER OPERATION
ENGINE / FUEL / DOES NOT TURN OFF/WARNING LIGHT
ENGINE / FUEL / OTHERS
MTOL - 5180 Dealer Repair Information
Symptom and Conditions
Some vehicles may set MIL DTC P0455 (evaporative emission control system
leak detected-gross). If so, follow the repair procedure below:
Repair Procedure
1. Retrieve and record DTC(s) and verify stored DTC P0455.
2. Record all freeze frame data and clear any DTCs.
3. Install new fuel cap part # FEY2-42-250.
4. Run IDS PDS Evaporative System Leak Test.
5. If test passes- return vehicle to customer.
If test fails- necessary to conduct further Evaporative System Leak
diagnosis.
Part(s) Information
FEY2-42-250 Fuel Cap
But if the CEL isn't on anymore, with the code still stored, you could just clear the ecu and then as long as the CEL doesn't come back on..TheMAN said:it makes your car fail state inspection in many states
TheMAN said:your argument is pointless
Kansei said:thanks for making the forums such a friendly place
but anyway. I guess what I was trying to say (and thought I did) was that if the CEL is off, doesn't that mean the test was run and there is no longer an issue? Therefore, resetting the ECU and letting it run tests again shouldn't turn up anything, but if the CEL does come back on, then yeah back to the dealership to get it fixed. I guess people don't feel like having to do anything like that on a new car, which does suck I guess.
Just for confirmation: Mazda does have a permanent fix for this, right? Either a new cap or leak detection pump, or both?
dhiney said:My CX-7 is at the dealer today for it's 3rd CEL. The dealer called MazdaUSA about the gas cap. I printed out this forum to show him what some of the problems are.
MazdaUSA said the warehouses have a new redesigned gas cap as of last Monday. They said no one should have known about the redisgn till it was in stock. The dealer is having one sent overnight hopefully to resolve the problem.
xavier said:Yay....I got my first cel I guess. My wife called me and said that an orange exclamation point came on and stayed on. I'm assuming its the cel. Yay...maybe I'll get a Speed6 as a loaner.
