Hello, this is my first post, so bear with me. I have a 2003 Protege5 with a cold air intake and a header installed by the previous owner.
I believe it also has a mil eliminator setup (electrical components spliced in). It has had a CEL light for almost two years which wasn't a problem until I moved to NJ where they test the ECU for emissions codes.
Yesterday I finally installed the cheap non-fouler solution found here that uses two adapters screwed togther that the sensor screws into.
After about 50 miles, the CEL came on again and the code is P0140.
Since the code indicates "no O2 activity", my question is whether a combination of the non-fouler and mil eliminator could be the problem.
Also if there are any other thoughts out there I'd appreciate any input.
Thanks.
Thanks.
