b_real45 said:
Excellent pics, Astral. I just hope I don't run into any clearance issues against the panel with my 1/2" spacers. Did you have to drill in any holes for the xovers?
What are your thoughts on the CDTs with the ED10k sub? Funny thing is that was what I wanted exactly and you already have it!!
Yes, holes were drilled for the xovers. Just two holes per x-over for the two screws.
The CDT's sound great and get pretty darn loud without distortion. I have tracks on which I sometimes wince when the snare hits.
Because I mounted the tweeters up at the sailpods, they sound a little harsh. Right now, I just turn down the treble a notch or two, and it sounds better. When I get to it, I'll take off the doors, open the crossover and flip the tweeter gain switches to -3db each (from current 0db).
Btw, servoeyes, I didn't have the treble turned down when I played you my system
I need to hear your HD-62s, I bet they're really nice
The low end on the CDT's is quite decent. I'd say that they are well qualified down to 100Hz.
The e10k.14 sub provides ample midbass and a little bit lower. It sounds clean (much cleaner after I put it in a properly sealed box) and gets relatively loud, but doesn't extend as low as I would like it to. I guess that's what I get with a 10" sub.
Now don't get me wrong: it extends plenty low for hip-hop, and rock music, pop and most of what you would call techno music, but the real lows between 25 and 40Hz get drowned out at anything higher than moderate volumes (I don't even know if the sub goes below, say, 30Hz). I'm a huge drum'n'bass fan, so I need "da bass".
So to sum it up: my current sound is great, but I just wish that the sub extended a little lower. Other than that, I get a s***-eatin' grin every time I drive to work and from work and whenever I'm blasting my favorite music
I do wonder what an e12k would sound like in my trunk, with the same power, instead of an e10k.
Also, last thing: order some eDead or RAAMmat or other Dynamat Extreme workalike and put that in between the CDT's and the baffles (I need to do that.. I get a bunch of rattles around 250hz right now). I am also planning on lining my trunk with eDead. Mind you, you have the 5, so your bass will sound louder.
