It depends on how truthful and accurate is the manufacturers power rating. If by maximum power output the mfg means the actual peak power of the amp (NOT the peak to peak power) as referred to the RMS power, then the RMS power can be calculated. The peak power = the square root of two (1.414) X the RMS power. Therefore, maximum (peak) power / 1.414 = RMS power.krstofer said:Hey guys, can you figure out the RMS wattage of an amp from the MAX wattage? is it like half or quater or something like that?
Thanks,
Krs
Tell us the brands and model numbers...we can get you RMS.krstofer said:I am just looking for a new amp since I fried mine last night. Some of the specs only show max power. I am shopping on etronics.com which has a store in NYC. I want to narrow my search before I go there today.
That's voltage though...means you have to work that math into the power equation.FoRNiK8ToR said:http://www.ece.unb.ca/tervo/ee2791/vrms.htm
in case you want to see the math... note that it only applies to an ideal periodic signal tho
(omg)servoeyes said:That's voltage though...means you have to work that math into the power equation.
P= (I^2) * R
V= I*R
Hence, P = (V^2 / R^2) * R or sqrt(P*R) = V, which is how we tell true power when we meter.
NO!!!!!!!!!!!!krstofer said:I am looking to get a 4 channel (or 2 2-channel) amp to power the stock speaks, but something I can use when I upgrade. Around 100-150w RMS. I would also like to keep the price around $150. There are a few on the site that show RMS like the one below, but I also want something that will look nice.
I am thinking of this on:
http://www.etronics.com/product.asp?stk_code=lanvibe428&store=&catid=306
here is the image:
http://www.carreview.com/Amplifiers/Alarms+VIBE428/PRD_286159_1806crx.aspx
I know MAX power means nothing. That's why i wanted to figure out RMS.
WELL SAID!servoeyes said:NO!!!!!!!!!!!!
Dude...a good 4x100 amp is expensive for a reason! Don't spend 150$ on one, because chances are that you'll regret it on down the road. Plus...100W to the stock speakers is pretty insane, in and of itself!
Is there a reason that you want a 4 channel to provide that much power to all the speakers? A decent 2 channel for the fronts and continuing to run the rears off of the stock deck is usually what I suggest. I prefer to have the sound stage in front of me, not behind. My car has about 80-100W (I don't have a test CD so I can't measure it right) to the fronts and ~20W to the rears. But...if you like a sound that's all around you, i can understand your reasoning.
Now...for an idea of how much a good 4-channel costs: My eclipse ea3422, their bottom line, drops 50x4 RMS and is clean as hell, was 250$. Can you spend less? Sure! But you'll be sacrificing some things...like THD, SN Ratios, actual power output, and overall SQ.
I don't plan to run full power to the stock speaks with the amp I buy now, so I won't blow them. I do plan to replace them in the very near future. I want to amp all the speakers because I don't like the sound of music coming from one direction ( I always got hte sweet spot in the house and movie theaters).servoeyes said:NO!!!!!!!!!!!!
Don't worry about one stupid long trip....there will be more trips to have louder tunes. Wait, save up a bit and get something on eBay, just be careful and read up on the amp you choose.krstofer said:Damn you guys.... No I am like, well maybe I should just wait.
I really want to get something though so....
If you had to buy an amp under 150, which would it be? any channel any wattage.
Krs
[edit]
I am hot to get one now because I am driving from NJ to NC on saturday. Otherwise I would probably order something online.
[edit]
