If its b/w engine failure, and you crashing into a wall at 90+ miles an hour, just throw it in neutral and brake, then shut the car off. fyi, the driver of the lexus this happened to was said to have been seen braking hard (as the rotors were glowing) Obviously in his panic they didnt think to put it in neutral, but not many drivers are have an understanding of putting it in neutral would do. Especially if youve never driven a manual car. .
Toyota's stopping tips :
Toyota also released these more detailed guidelines for an emergency stop:
* If you need to stop immediately, the vehicle can be controlled by stepping on the brake pedal with both feet using firm and steady pressure. Do not pump the brake pedal as it will deplete the vacuum utilized for the power brake assist.
Shift the transmission gear selector to the Neutral (N) position and use the brakes to make a controlled stop at the side of the road and turn off the engine.
* If unable to put the vehicle in Neutral, turn the engine OFF. This will not cause loss of steering or braking control, but the power assist to these systems will be lost.
* If the vehicle is equipped with an Engine Start/Stop button, firmly and steadily push the button for at least three seconds to turn off the engine. Do NOT tap the Engine Start/Stop button.
* If the vehicle is equipped with a conventional key-ignition, turn the ignition key to the ACC position to turn off the engine. Do NOT remove the key from the ignition as this will lock the steering wheel.
agreed not everyone will remember to throw it in N, but also sometimes the gear selector will not be possible to throw into N either. In an emergency situation I'm not sure we ourselves as informed drivers can say with absolute certainty that we will remember ourselves if put in the same situation.
I understand you were trying to make a point too, but I don't see any of toyota's cars having the capability to run up to 90MPH when on the brakes <_<;
