yes, but I am saying that a less efficient intercooler can only lower the temps a certain percentage. a perfectly efficient intercooler will lower temps to ambient air. but a stock MSP intercooler (mostly because of location, and loack of direct air hitting it) will not be able to attain 100% efficiency, thus it will only lower the temps as a function of the intake air temp.. YES I know how hot a compressor gets but a cooler starting point will = a lower ending point in this scenario.... ESPECIALLY when the starting temp is a 40 deg difference (as found in this particular test)
now if the engine layout were different, then we wouldn't see such drastic differences in temperatures between the SRI and the CAI... I would personally prefer a SRI, but if the angles required are tight and many, then you might as well put it in the fender. but in a given engine bay where there is room, or where the filter doesn't sit within direct pathway of the radiator fan then we wouldn't see such a huge difference in temp, and the whole argument would be rendered moot
