not necessarily. depends on how well the system was designed in the first place. while a stock valve shouldn't leak at stock pressures that isn't necessarily true.So i am getting the impression that unless i have done enough work to the motor/turbo to produce a higher psi, i do not need to upgrade this?
yes, any kind of AIR you are taking out of the system post the MAF sensor will result in some kind of a powerloss, even a 50/50 setup
think about it this way. your MAF counts air particles. it knows at any given moment how many pieces of air are in the system. it adjusts fuel accordingly. if you remove some of the air it has no way of knowing how much you've removed so it will not adjust the fuel. so you'll run rich. that means your power will be less.As some have mentioned, with BOV running VTA you would loose a little power, Would this also happen if you ran something like Turbosmart 50/50, going 50 recirc and 50 vta?
edit for clarity....
