As the original creator of the BOV/BPV setup (who is very rarely on here anymore these days), I am amazed to see how much misinformation is out there about this now.
Hope I can clear up a few things.
Speed_Racer said:
1. you can just use the same source as your boost gauge or just T into the stock bpv line.
No. This is 99% of the time what someone did wrong when they PM me with problems on their install. If you use the same source for the BOV, BPV, and wastegate, the car will not run as well. Instead, use the brake booster line for the BOV and BPV, then run a new untapped hose from the intake manny to the wastegate.
Speed_Racer said:
2. a bov should ideally be place 6-7" from the throttle body.
After more testing, this actually doesn't matter much. In fact, if you put the BOV on the hot pipe and the BPV on the cold pipe, it ends up working a little cleaner in theory.
Speed_Racer said:
its really a preference thing.
That's more like it... set it up however it will be cleanest for your setup and in your mind's eye.
Maxxpwr said:
http://www.mazdas247.com/forum/attachment.php?attachmentid=98234&d=1168156025 okay, this is the duel setup, much better picture. im not really sure, i've heard people completely against the duel setup and saying it causes compression surge and stalling.
100% wrong... that is exactly what my dual setup CURES... not CAUSES.
Maxxpwr said:
...also heard the rpms are suppose to drop smoother.
Nope... not if the dual setup is installed correctly that is.
Maxxpwr said:
its just gonna be dangerous move cuttin those hardpipes.
You also have to be at least slightly concerned with the longevity of your MAF sensor, considering it wasn't designed to see a boosted airflow.
Speed_Racer said:
dual setups are better than VTA (Vent to atmosphere) after the MAS setups. I've seen nothing but good things from dual setups, aside from the blow off valve being quieter, but it makes up for that with a more unique sound and driveability.
(first)
For a timeline on the progression of the original BOV/BPV setup with several pics, soundclips, and videos, check out the build-up thread in my sig. The setup starts in the October 2003 section, revision #1 is in may of 04, BSC reflex added jan 05, revision #2 march 05.
As always, feel free to IM or PM me with any questions.
