mikebontoft
- 02 Focus SE, 90 626 GT
^^ lol goddammit..... that's the exact opposite someone else told me today. The 1.6 and 1.8 might be non-interference, but the 2.0 is interference........ (braindead
the cams were NOT completely out of the head. they were totally loose though, I was able to pick them up and almost pull them out. they SHOULDN'T have been sitting on any valves.
but then again my teacher is kind of an idiot..... takes the "technical" approach to everything. I usually do everything the opposite he tells me and it works fine. lol.
OK anyway though, I thought I'd give a better in-depth idea of what I did. If I didn't mention it, I DIDN'T DO IT
Let me clarify just in case I didn't do what you guys think I did (or didn't)
found the engine with a snapped (right at the top between the cams) timing belt. I could rotate the cams with a wrench if I needed to.
I undid all the cam cap bolts enough to pull the cams out so they were not pushing any valves down. (so I was told to do)
Took the schrader valve out of the compression checker hose, took out ALL spark plugs, threaded in the hose, attached the compressed air line to it, and air blew out either the intake or the exhaust depending on the cylinder.
DID I DO THIS RIGHT?? I guess I'm taking the head off tomorrow morning if no one can correct me here.
I was thinking that maybe if I set the timing marks and put the new belt on, tighten everything up, and thread in a compression checker, maybe I'd get some readings on it. (considering the fuel pump is dead... otherwise I'd just see if it started)
