hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Then it isn't a problem with the AFC, the AFC is only commanded on when the car sees boost. 440 injectors will not help you run richer, they are required if you are running over ~14-15psi.
