deckedoutmp5
- 02 MP5 #3256
ok on the 626 same motor as our car, but in japan they use the direct coil single pack. i would like to do this conversion on my car so that i can run msd. usually stock ignition for NA is always better and if your motor dont have enough "umph" msd usually takes away power, but on boost i want it.
juan, i know you will know this because you work with the jspec cars and stuff, but does anything have to be done via main wire harness or anything? thanks- trav
