A local dealer finally got two Sport manual CX-5's in stock (Hall Mazda in Virginia Beach; one Metro, one Silver), so my wife and I stopped by for a test drive. I had already previously driven a Touring auto and was impressed, but still wanted a manual transmission. We noticed that there was a slight resistance getting the shifter to select 4th gear, and the only way to ensure a smooth engagement meant letting the clutch out slightly while applying pressure to the shifter. Sometimes it dropped right in with no problem, and the resistance didn't appear to by linked to a specific rpm or range. Has anyone else experienced this issue?
Also, shifting into 6th takes some getting used to. A: that is where reverse has been on my past two vehicles, B: the shifter naturally pulls towards the center neutral position which resulted in both my wife and I downshifting to 4th a few times versus 6th. I'm not noting a mechanical issue, just an observation from two drivers.
