- Plano, Texas, USA
Yes, that should be the proper way to do the tire rotation on directional tires.I would just rotate them front to back and be done with it.
From Tire Rack:Anyone tried the Toyo Proxes ST3? Classified under Performance Truck/SUV and Highway (unlike others CUV/SUV and Touring and All-season). Guess they'll wear faster though and ride might not be as good, but reviews show they're good in dry and wet.
Saw a Falken FK510 but they're priced bit higher than the ST3 (like around $270ea). Wonder how the Proxes ST3 would do with our CX5, as I'm planning to upgrade from the stock 17's.
Not fortunate to easily find Continental (and others from the US market) here in Asia.
The ST3's are like $165 ea. here.
Sorry, in what ways will these 'Performance tires' be unsuitable for the CX-5 CUV?From Tire Rack:
“The Proxes ST III is Toyo's Street/Sport Truck All-Season tire developed for high-powered and performance-focused pickup trucks, crossovers and SUVs, in addition to any driver who wants to add some sporty character to their vehicle. Designed to combine stylish good looks with confident traction and handling year-round, the Proxes ST III is engineered for use in dry, wet and wintry conditions, even light snow.”
And:
“The Azenis FK510 is Falken's Ultra High Performance Summer tire developed for the drivers of sports cars, sporty coupes, performance sedans and modern muscle cars who want dry and wet traction and handling in a refined package. The Azenis FK510 is designed to deliver driver confidence in warm conditions, so like all Ultra High Performance Summer tires, it is not intended to be serviced, stored nor driven in near- and below-freezing temperatures, through snow or on ice.”
I’d say both “high performance” oriented tires aren’t the ideal tire for your 2022 CX-5 Sport FWD 2.0L which is a CUV.
You can go to tirerack.com and look through all available 225/65R17 tires which aren’t under performance categories and check customer reviews. Then find the tires available locally from top rated tires listed on the chart.
A CX-5 with a 2.0L has only 155 hp. It’s mediocre at best for a crossover utility vehicle on power and performance. You don’t need a tire designed for “high performance” or “street sport”.Sorry, in what ways will these 'Performance tires' be unsuitable for the CX-5 CUV?
newsflash, some people like to go for a sportier tire option that regular old mediocre all season tires. Everyone knows that Mazda CUV's tend to handle better than the typical offering from other makes. Maybe @sherp wishes to enjoy some benefits of that handling with some higher performance rubber.A CX-5 with a 2.0L has only 155 hp. It’s mediocre at best for a crossover utility vehicle on power and performance. You don’t need a tire designed for “high performance” or “street sport”.
Yes I agree. And that’s why I said “need”, but he certainly can get it for any other reasons. Since sherp is from other country where the tire price can be much higher, my suggestion has mainly considered the cost issue as most of time the performance tires are more expensive but with much less tread life. And if his area has wintery road conditions occasionally the performance sumner tires may not be a good choice for him.newsflash, some people like to go for a sportier tire option that regular old mediocre all season tires. Everyone knows that Mazda CUV's tend to handle better than the typical offering from other makes. Maybe @sherp wishes to enjoy some benefits of that handling with some higher performance rubber.
Among 2 tires you mentioned, Toyo Proxes ST III all-season tire certainly is the better choice with “500 A A” UTQG and lower price in your area ($165 vs. $270 each). It’s a street/sport truck tire and the ride could be firmer than your stock 17”’s. And I’d stick with OE size 225/55R19 and Proxes ST III doesn’t come with 225/55R19 at least in the US.Yes, primarily our reason was aesthetics. Of course I also consider the other factors (ie. wear, comfort, cost, noise).
Started as there were 1 year old, stock 19" stock rims offered for around $350 by someone who upgraded rims, so I scouted for tires, as long as not too expensive. Though limited, stock 19" tires Toyo R36/R46 are priced too high (like $400each), and the 2 I mentioned earlier (ie. Toyo ST3 and Falken FK510) were what I found available and priced good enough. Later I also found the Sailun Inspire, bit cheaper, but really couldn't find reviews.
I learned later that the 2 tires are 'Performance Tires' but wasn't too sure of the impact on our CUV. I would have considered them if wear and comfort were not sacrificed significantly over stock touring tires, since I read they were fine Dry/Wet, but then the classification of 'Highway' and 'Light Truck' got me more confused, which is why I inquired.
We're in a tropical country (dry/rain), so no winter at all. Obviously there are bad/uneven roads, roughly on 30% of usual trips. I don't generally do 'spirited' driving,
Been reading too to get inputs regarding tires as I'm not too experienced with these, why I inquired. Thanks for the inputs.
The concern to me by using wider than stock 225/55R19 tire is this:Been combing threads here for tire options a bit after inheriting my father in laws pristine 14 gt AWD with just 17k on it but still the original toyos. it's nice to be back in a Mazda, we had first gen Mazda 6 and 3 years ago.
I'm not thrilled with the options that are in the OEM size which seem to have been selected more about maximizing mpg than anything else. That being said, you all have me scratching talking up 235/55r19 while talking down 245/50r19 when both tires are ideal on a 7.5" wheel but still spec'd to fit on the OEM 19x7 wheels. Especially since the 245/50 is an exact diameter match without any negative impact on the speedo. I've pretty much landed on Conti dws 06 plus which comes in both sizes. Have had the regular dws06 before and loved them
Interesting, based on height on the strut it looks like it would be closer to where the tire mounts on the wheel where it rubbed.The concern to me by using wider than stock 225/55R19 tire is this:
The rubbing mark is on both sides of front struts on my 2016 CX-5 GT AWD and was caused by stock Toyo A23 225/55R19 tires.
It's subjective. I was happy with my oem A36's other than some vibrations for the first few miles. Wear was as expected. Traction was fine. Nothing to make me throw away good tires. I don't think it would be an issue finding an A36 if you needed a replacement.... The question is... are the A36s this bad? ...
Pirelli's Cinturato P7 All Season Plus II is an excellent tire based on Tire Rack comparison chart. The only concern you should have is its 225/55R19 99H is H rated, and Pirelli won’t offer any warranty if your factory tires have higher speed rating, which is V rated on your stock Toyo A36’s. Some tire stores may offer their own warranty but you really want to verify.Costco Canada has $150 off on Pirellis right now, so I have been thinking of potentially getting a set of Cinturato P7 All Season Plus 2s. I assume I can sell the Toyos that my CX-5 came with (they are literally brand new).
The question is... are the A36s this bad? I'm sure that once I start rolling on the A36s they will have virtually zero resale value. I don't want to have to replace them mid-summer, and I am also quite scared of not being able to find a replacement A36 in case I get a flat or something.
PS: Blackcircles in Canada has an even better deal on those tires. Less than $1000 taxes and installation included.
Unobtanium had been reporting his experience on Nokian WRG3 SUV 225/65R17 on his previous 2015 CX-5 Touring AWD.
Nokian WRG3 SUV (ongoing review)
Definitely it’s the rubbing mark from my Toyo A23 tire! Nothing loose on both sides of front suspension and I’d noticed these rubbing marks on both sides since my 2016 CX-5 was at 30k miles.You sure that wasn't from installing/removing the wheel from the car?
I do that all the time when installing/removing.
If you have that much movement between the wheel/tire and the strut when driving, something must be worn out....although there's not much there. It's a fairly rigid connection from wheel to the strut.
Just talking out loud, I think it's only the hub attached to the knuckle and the strut is bolted directly to that.
