Hello all!! I'm new at this but here goes....
I have a 2002 Mazda Protege LX, 2.0 liter. I was driving with the cruise engaged when the car felt like it lost power and the CEL started flashing. Took the cruise off, depressed clutch, revved engine, finally power was restored. CEL stayed on constant. Finally took it in to the shop and they advised that I had a multiple cylinder misfire code. They wanted 700 for a basic tune up well. I decided to replace some items on my own. I have replaced the PCV valve, air cleaner, plugs, wires, and the top O2 sensor. I ran injector cleaner through (Lucas) two tanks of gas. Then I replaced the coils (both). After each item, I reset the CEL. The light is back on. I am now getting a P0421 code (reset and verified twice). The code indicates a warm up catalyst system (RH) efficiency below threshold.
Probable cause:
aa1, exhaust leak (cant hear one),
aa2, check other service codes first (none),
aa3, faulty catalytic converter.
Idle bounces occasionally (below 500 to 1000, levels at 750). Some hesitation.
I am considering replacing the lower O2 sensor (at 108000 it is probably time anyway).
Not sure what to try next before I take her back to the mechanic. Ideas?????
Thanks
Probable cause:
Thanks
