that other thread is mine
the only "Required" parts for the swap are the coils and wires. to make the swap more betterer, i suggest getting the valve cover, as has been mentioned. i could never get the wires to seat correctly on the plugs with the stock valve cover, and would get random misfires.
for my swap, i used the following:
- 99-00 1.8 coils (pick your favorite brand)
- 99-00 1.8 plug wires (NGK are the best for the least money)
- 99-00 1.8 protege or 00+ 626 2.0 valve cover
those are the only parts you NEED.
i also added the coil brackets from the 1.8 set up, but they are not required for the swap. to mount the coils to the front of the engine, like shown in "i12drivemyMP5"s picture, there is a threaded bolt hole on the head. just get a bolt with the correct thread, and mount it up.
the 2.0 coil plugs on the harness will plug right into the 1.8 coils. to get the plugs to the front of the engine, just unwrap the harness tape, reroute the wires, and re-wrap the harness.
for an ever smoother set up, get NGK plugs from the 1.6 protege. they come stock on the 2.0 JDM FS-ZE. they have an extended tip, and provide a better spark location for better fuel ignition.
if you have any specific questions, post them up. i'd be willing to help out as much as i can.
