I picked up an 08 3 Wagon at the end of last year. The only issue I am having is that after driving for about 40 minutes, the air starts to blow cool. Typically I start with the heat at 69deg. When it starts to cool down, I turn it up 1deg and it is fine for about 10 minutes and then starts to cool down again. On long trips, I have had the temp gauge turned up to 79deg to get warm air. Engine temp is rock solid where it should be. Temp sensor tests OK and the thermostat and housing have been replaced.
Anybody else experience this or have any ideas on what might be causing it?
