Last week I started working on the sound deadening, and was able to do a bit more this weekend. I bought materials almost a year ago and had it on my to-do list since forever... Just now getting around to it. :/ I really should have put more priority on getting this done sooner, it really bugs me how damn LOUD this car is (and not in a good engine or exhaust note loud kind of way).
The CLD tiles are RAAMmat, the CCF is ensolite sourced from RAAM, and the MLV I got semi-local at a home theater place.
I'm using 1/2lb MLV instead of the more common 1lb MLV in the interest of weight. It should still be a vast improvement. It will be about a 40-50lb weight penalty, but in this case, for this car (DD) it is worth it - this thing is just a loud, echo-y, road noise-y, tin can.
Here are the CLD tiles in the rear of the car:
The rear panels were a PITA, as they are deeply sculpted and I tried to make them out of a single piece with as little patching as possible. The floor is about 1000 times easier/quicker. I think that even the doors will be quicker because even though they have a lot of wiring to run through them, they are not the deep 3D contours of these rear panels.
Here is the LH rear panel. I chose not to cut/shape the CCF/MLV to go behind the jack. In addition to making life easier by not having to form that pocket, it probably deadens more effectively. In the rare instance that I do get a flat, I will just need to cut through the MLV (can easily be ripped by hand) to get to the jack. Of course, now that I said a flat isn't likely, I'm going to get one next week...
Here is a close-up of how I worked the CCF/MLV behind the rear speaker and CSA:
Here is the trunk section mostly finished:
Yesterday I completed the trunk area, and did the floor up to the rear of the front seats. I still need to do the front of the floor, and all 5 doors.
With the trunk and middle/rear floor compete, the results are interesting. The vehicle doesn't SEEM much quieter at first glance, but the drive home was kind of disorienting because the sound was very different. I do notice a difference in sound level, but maybe not as much as I'd hoped for how much work I put in this weekend - BUT: all the work I did is in the rear of the vehicle. When I poke my head around the headrest and lean back to listen to the rear of the vehicle, it is REALLY quiet.
What I think is going on is that I've made a significant reduction in sound from the rear of the vehicle, but not from the front or doors. When I'm sitting in the front driving, I'm sitting closest to the noisiest parts of the car (FR tires, engine, etc) and that noise is still present 100%. The part of the car that I've deadend is the rear of the car, which is much farther away (remember sound intensity drops with the square of distance) - so despite the fact that the rear is much quieter, it is still dominated by the noisy front of the car. I think the slight disorientation feeling that I mentioned was the fact that I was still hearing lots of road noise (overall levels about 80% of original), but I wasn't hearing anything behind me like I was used to.
