Grey Msp Rebuild Round 3
Mazdaspeed Protege
Hello everybody raising from the dead is my grey msp that has been sitting for the past 9 month not moved or wash once since my rod bearings gave out finally pulled out the motor. Ive had a spare engine waiting a 52k clean long block long before the engine threw a rod. This is the third time its getting fully remodded this time the car will be more track ready. Basically the reason why im starting a new thread is that i just want to get past all the past drama of part outs and paint job issue i went threw lol.
So recently towed it to the new house and now have a garage a lot more time to work on the car this is what it looks like at the moment
-To start with mods recently picked up a Dg motorsports hood with the naca scope and will be re-clearing the hood. The first thing i did was wash the car. Its was repainted didn't come out oem color (lets not bring up past drama) so im dealing with it. The spoiler holes saved, the protege emblem and mazdaspeed emblem saved of but not the flyin M.
I currently do have 2 proteges my DD is the black protege in the back ground. This is my front bumper setup brand msp bumper with p5/msp fog deletes with a modified msp lip to work with the bigger fog deletes. Debating on getting a carbon grill to go along with the hood from DG motorsports. Currently finish up the lip making mounting brackets for a flush fit then sanding it down and prep for primer.
Some mods I've been collecting will start assembling soon
505zoom V2 intake manifold plus jays racing thermal spacer kit. I will be sending the throttle body spacer and a oem throttle body to max bore for porting soon. Planning on getting the Jays Racing fuel rail. Debating on STI 565cc pink injectors
505zoom gauge rings. Looking for a canadian black cluster hit me up if you got one lol!
505zoom crank pulley
Medieval power steering pulley
For the interior i have a DG motorsport center counsel will be getting the shifter surround as well
Custom dual gauge pod and a center forced fed gauge pod
AEM wideband and tru boost gauge. Will be purchasing a AEM digital oil pressure.
For tuning i got the haltech platinum 1000s with gm 3 bar map sensor and a aem coolant sensor. Its fully pre wired.
GTX3076r will be purchasing a internally gated t3 exhaust housing.
Begi top mount
A full custom 3in exhaust will be built using a HKS legal muffler plus pre silencer and resonator.
GoodRidge clutch line
Spec Aluminum Flywheel
ACT stage 3 HD clutch
HKS oil cap
HKS Super Sound bov
NRG carbon hood dampers
Forged Valve stems
SpeedCircuit straight thermo stat outlet
AXR clunk fix kit plus energy bushing plus oem racing beat sway with energy bushing clamps
YellowSpeed Coilovers installed already
Everything thats underlined is installed
PERFORMANCE
505zoom air diversion plate powder coated black
505zoom valve cover dress up kit
Jays Racing thermal intake manifold spacer
Haltech Platinum 1000s W/ 3 bar map sensor plus coolant temp sensor
Garrett Gtx3076r
Carrillo Pistons 8.5.1 comp .020 overbore
Oliver H-beam rods
Begi Top Mount turbo manifold
HKS 3in hi-power carbon muffler
HKS super sound bov
HKS oil cap
Custom Grounding kit using all stinger hpm products
Corksport 52mm Radiator
Street Un1t radiator mounts
Speedcircuit straight thermo stat outlet kit
Ion intercooler core
DRIVETRAIN
Mfactory LSD
ACT Stage 3 HD clutch
Spec Aluminum flywheel
Goodridge Clutch line
Redline mt-90 trans oil
Custom extend trans brace made by ferdi
Corksport Bronze shifter bushings
Corksport 3rd link bronze bushings
Torque Solution shifter bushings
SUSPENSION
Yellowspeed Coilovers
AXR clunk fix kit
Energy Front and Rear sway bar bushings
AWR rear adjustable sway bar links
AWR front adjustable sway bar links
Whiteline LCA bushings
New lower control arms w/ball joints
New tie rods
BRAKES
Painted red calipers
WHEELS
BSA (rpf1 reps)
Kumho escta le 215/45zr17 17X7 40 offset
Hub-centric 3 mm spacer all around
Red Forged Stems
EXTERIOR
DG motorsport NACA hood
NRG Carbon Fiber Hood Dampers
Modified Front 03.5 MSP lip
Dewinged, Debadged minus Flying M
2003 P5/MSP fog deletes
Wings west roof spoiler
Depo protege taillights with Amber overlays
Mazda Tribute side marks
505zoom sap kit
New paint:(
INTERIOR
505zoom Gauge Rings
Canadian black cluster
DG motorsport carbon center console
DG motorsport carbon door sills all 4
DG motorsport carbon arm rest, shifter surround, and passenger dash piece
Custom Dual Cluster
ForcedFed center steering gauge pod
AEM air/fuel Wideband
AEM tru boost controller
Sony XNV-660BT Double din
DDM Led light Cluster,Center Console, Dom lights
Vms carbon fiber shift knob
Future plans and buys
PERFORMANCE
Send throttle body and Jays racing spacer kit for porting to max bore - picked up an extra throttle body
Jays Racing fuel rail plus pump kit
Apexi Power Chamber filter
Custom Intercooler and intake piping built
Custom Core
Custom 3in turbo back exhaust built
Polyurethane Exhaust hanger bushings
Oil catch can
Apexi condensor
Doc B oil system plus prv and all the goods
Nology Hot wires
DRIVETRAIN
Mfactory gear set 3,4,5 plus final drive and lsd
SUSPENSION
AAC lateral link kit
AWR trailing arms
Cr3 autoexe suspension things dont know what to call them
BRAKES
FD front calipers
Goodridge stainless steel cover black brake line
WHEELS
PowderCoat the FDs color don't know yet maybe a dark green color or something close to carbon
New spacers all around possibly 5mm spacer
New tire 245/45 or 245/40
EXTERIOR
Plasti Dip anthracite grey
Carbon trunk
DG Carbon grill
INTERIOR
AEM digital oil pressure gauge
Sub! Can I Ask where you got the Haltech from?
i just want to say thanks to everybody and hopefully ill be able to finish it up in the next 6 months ill definitely keep everybody posted and check out other build threads for ideas to reflect on
Haven't done much with this grey msp just got bored and decided to install the new wheels i got for my black msp on the grey map
I started to transfer all the work i did to my black msp to the grey msp started with the brakes then the front subframe since it has whiteline control arm bushing kit installed
Swapping over the front subframe and coil overs Also have front energy bushing for the front sway bar and the control arms are new as well fitted with whiteline bushing
Im getting the 50k engine i have for it ready gave it a repaint i installed the 505zoom crank pulley and the medieval power steering pulley installing the walbro fuel pump also my dpuble din is going in
Resprayed a couple parts
touched up the calipers
