Great job on this
Thank you for posting
I'm gonna try this
But what is up with running speaker wires through the engine bay!? Can speaker wire shielding hold up to the heat in the engine bay? They are for meant for interior use only. Luckily blinkers draw low current and infrequently used (opposed to fog light/low beam) but that’s just not a good idea, not to mention it looks pretty bad.
Good to see the lesser MZ5s still have the wiring for those who want to add tweeters.
You can probably just tap into the rear turn signal wire from the rear wiring harness, somewhere close to the door.Good luck
I'd say it would be easier if you can trace the turn signals inside the car, maybe on the fuse box, I did not take the time to do that as I was running a cable to install
front camera anyways so I ran all cables at once.
Be VERY careful heating the mirrors to remove them, if they don't get hot enough, they will brake when you try to pry it off, if you overheat, you will deform
the back plate and screw it up.
Post how it went
Actually you can wire it to BCM for a shorter route at per your diagram. I did not have the diagram at the time.You can probably just tap into the rear turn signal wire from the rear wiring harness, somewhere close to the door.
