How To: Sedan Headlights ----> P5 Headlights / P5 Headlights ----> Sedan Headlights
Now like any how to, I will not be responsible for anyone attempting this mod and not installing them correctly or causing damage to their vehicle. You do this mod at your own risk. Viewer discretion is advised, you have been warned.
Disclaimer: The only credit I take is the drawings I made for this how to. The information was already posted by several previous members on here as all I did was make it much more clear with illustrations.
Bibliography:
thewrench
TheMAN
As always attempt to use the OEM H7 adapter as it aids in seating the bulb correctly and provides a base for the bulb retainer clip to apply firm pressure. When the OEM adapter is used, substitute the female spade connectors for an Aftermarket Female H4 Plug as the adapter is made to connect to it like OEM. If not, you will need to use the female spade connectors and something to help seat the bulb like this aftermarket adapter pictured below. You could essentially use female spade connectors for the contacts if you so desire. This is entirely at your discretion.
Good Luck!
Bibliography:
thewrench
TheMAN
Good Luck!
