Yes they will.....1993 steelies from an Eclipse/Talon/Laser fit perfectly. If you can't find those specifically look for 14x5.5 +35 offset with the 5x114.3 bolt pattern and a hub bore of 67.1. My current set-up includes '93 Eclipse steelies with 185/70/14s with no rubbing, the recommened size would be 185/65/14.
thanks for the response, maybe i'll pick up the set from my buddy for the winter
Hey, I found a set of 185/70/14 tires for sale at a great price, doing the math it seems they'll be 13.2mm larger in diameter than the stock wheels (195/50/15). That won't rub with the stock suspension right?
I've had no rubbing issues at all while running these the last two years at stock height.
As long as they are the 5 bolt pattern I don't see why not....
Offset will vary by year, model etc, ie: Protege5 are +50, 06+ MX-5 are +55 (16" wheels), Tribute are +45 etc....sadly I don't know the offset for the 626....
Any advantages to going with 14's vs 15's other then price? 185 is skinnier then the 195's usually listed for 15's IMO I was always told that a skinnier tire did better in the snow/ice but that's just the old man's opinion, never really had a chance to check it out. Though my old Tempo with 185's was one of the better winter beaters I've ever had, never did get that stuck.
14" 626 steelies worked fine for me on my p5 I still had one as a full size spare...
