Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2008 CX9 replacement smart card
  1. #1
    Registered Member
    Join Date
    Aug 2010
    Posts
    2
    New owner of 2008 CX9 and we only received 1 smart card key. Dealer wants over $500 for additional key and programming!
    Are there any alternatives to this high cost from a dealer? We would like a spare smart card key but at $500 that's pretty excessive.
    Thank you in advance,
    Registered Member Force-1's Avatar
    2008 CX-9
    Join Date
    Nov 2007
    Location
    Albuquerque, NM
    Posts
    476
    2008 GT AWD, GT Assist Pkg, Moonroof/Bose Pkg
    Sparkling Black Mica
    ***Gone but not forgotten***
  3. #3
    Registered Member
    Mazda3 S Hatchback
    Join Date
    Mar 2010
    Location
    Las Vegas, NV
    Posts
    42
    I bought mine off of Ebay for around $70. I luckily had two working smart keys, so I was able to program it myself. Since you only have 1, you will still need to have the dealer program it.
    ________________________
    -Travis
    2010 Mazda3 S Hatchback Manual
    2012 Toyota Camry XLE Hybrid
    1992 Toyota Celica All Trac Turbo
  4. #4
    Registered Member
    Mazda CX-9 GT
    Join Date
    Sep 2010
    Posts
    1
    Is it safe to buy from ebay, i also need a spare smart card. I only have one set from my dealer.
  5. #5
    Registered Member ceric's Avatar
    2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    3,828
    If you buy from eBay, please make sure that
    1) you get the right one
    2) you get a brand new one
    The problem is that if you only have one working key, the dealer may not want to program a key
    you bought from eBay (in general, elsewhere). They most likely only program one that is bought from them directly.
    So, I would suggest that, do some cross-shopping among all nearby dealers and get the lowest price (part + programming).
    If you have two working keys, you certainly can program a third one yourself.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  6. #6
    Sexy-9 SeCX-9's Avatar
    Mazda CX-9, Grand Touring, Loaded
    Join Date
    Jun 2008
    Location
    Worcester Area
    Posts
    526
    Now that I think of it......With Two CX-9 and Two CX-7 smart keys, do you think I should be able to program my CX-9 smart card to operate my wife's CX-7? and visa versa???
    This might be really convenient to use my key/card on her car instead of digging up her spare....thoughts? This won't disable either of my two will it?
    2008 CX-9 Grand Touring AWD + Assist Pkg + Moonroof Pkg - Blue Mica - Yoko Parada Spec-X
    2009 CX-7 Grand Touring AWD + Technology Pkg + Remote Starter + Chrome Package - Crystal White Pearl Mica - Yoko Parada Spec-X
    2008 Revision G Navigation
  7. #7
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    3,828
    SeCX-9,
    You know my wife has a Prius, which has SmartKey system also (but from Tokai-Rika, not Denso like our CX9's).
    On Prius, many people have tried and failed because the Key actually remembers a "Smart Code" inside the key.
    The Smart Code is from the vehicle's ECU (unique code for each SmartKey system). You can't program the key for
    another vehicle until you reset it (take $$$ to do so). Once you reset it for the second vehicle, it loses the "memory"
    to talk to the 1st one. Therefore, no one has made it work on Prius' Tokai-Rika system.
    On CX9, no one seems to have tried it. Want to be the 1st?
    The Smart Code issue is also the reason not to buy an used one from e-Bay. On a Prius, you still can program it
    half way, meaning, you can't use it remotely. You have to stick the Key fob into the key hole to start the engine.
    All the "SmartKey" functions do not work properly.
  8. #8
    Join Date
    Jun 2008
    Location
    Worcester Area
    Posts
    526
    Ceric....Hmmmm
    That's what I am wondering is if the ECU memorizes the RFID of the key, or if the ECU actually transmits a security code to program the remote key foble....I'm thinking not but....not sure I want to spend $500 to fix a screwup on my part.. Her CX-7 is under warranty, so maybe I can just say it stopped working....
    Anything in the tech manual on this?
    Maybe I'll call a dealer.....(Not mine so in case I need to bring it in)
  9. #9
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    3,828
    SeCX-9,
    I think it is both. The ECU definitely memorizes the RFID. I am sure of that. I saw related descriptions in WorkShop manual.
    On a Prius, apparently, the key also memorizes the ID of the ECU. Not sure about CX9's system.
  10. #10
    Registered Member
    Join Date
    Jul 2009
    Location
    Irvine CA
    Posts
    263
    For those of you who need another "smart" ignition card, buying from a ebay seller is OK but just know that most of them are used with no guaranty that they work. I have purchased two cards from the same seller, remotes.inc , and one of those died soon after I got it programmed by the dealer near me. The first one has lasted over two years with only a new battery needed after more than a year and a half. Be very careful about exactly what you are purchasing! Some cards are only the case WITHOUT the electronics inside! If you still have the hard mechanical key, it will get you by in a pinch.
  11. #11
    Registered Member
    '15 WRX
    Join Date
    Feb 2013
    Location
    Chicago, IL
    Posts
    455
    My used speed6 came with only 1 smart key & I paid about $300 for a new key from the dealer & $65 to program it. So about $400. There's no other way around it if you only have 1 key. You'll need the dealer to program it.
    I thought about buying off of eBay, but for ~$100 or more, I didn't want to risk buying one DOA, so just bit the bullet & got it from the dealer.
    Try finding coupons for 10% parts from the dealer to help with the cost of the card.
    GL
    '14 CX-5 GT AWD Tech Package, Crystal White Pearl
    '07 Mazdaspeed6, traded in for a '15 CWP WRX Limted on 12/5/2014.
  12. #12
    Registered Member knowaczark's Avatar
    '08 Mazda CX9 GT Black
    Join Date
    Sep 2009
    Location
    So Central PA
    Posts
    218
    I just replaced my missing 2008 CX9 Smartcard with a used replacement from Remotes Inc. Contact John at remotesinc@gmail.com
    Had a few minor glitches but in the end the experience was gratifying and I would recommend them.
    Emergency key has been cut locally and the smartcrd and key synced at my dealer for under $50
    2008 CX-9 GT AWD
    Moonroof/BOSE/Sirius/BSM/Tint/Roof Rack-Rails/SS Rear Bumper Step/
    LED exterior & interior lighting/Fogs on w/parking lamp on mod
  13. #13
    Registered Member
    2007 Mazda CX-9
    Join Date
    Sep 2011
    Location
    somewhere
    Posts
    110
    I bought mine on amazon and its a little more to pay than ebay but it works and its brand new with a blank key and a battery. I bought one to replace a fob on my 07 cx9. Coz the button is all gone from pressing by the previous owner.
  14. #14
    Biggie T Skinny helbigtw's Avatar
    CX Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    1,926
    I've bought 2 on ebay, and the only reason I had a problem with one is because the local service retard manager dropped it on the concrete floor from 4 feet right in front of me.
    Key is to make sure the seller has really good photos of the cardkey, and yes, NEW is prefered.
    08' CX-9 GT FWD
    Color: Gray Mica with Black Interior
    OEM Options: Nav/Bose/Sunroof/Bluetooth Phone/Rack&Crossbars/BSM/Pwr Lift/Homelink&Compass Mirror/Tow Pkg/All Weather Rear Mats
    Aftermarket: K&N drop-in filter/Centric E-Coated rotors & Centric Posi-Quiet Ceramics /Yakima ForkLift Bike Tray / Weathertech front mats
    Tires: Nitto NT850+ CUV
    Oil: Mobile One Full Synth 5w30
    Problems to date: Blower motor relays replaced once, intake manifold rear brace was missing from factory build, headlamp motors are dying
    Mileage: 91k March/16'
    Job: Auto Physical Damage Adjuster
  15. #15
    Registered Member
    Mazda CX9 2008
    Join Date
    Aug 2013
    Location
    UAE
    Posts
    4
    I am having Mazda CX9 2008 with 2 Mitsubishi Smart Card Keys with 3 bottoms; Lock, Unlock and Trunk Open. Can any one advise from where I can buy same? Regards.
Similar Threads
  1. Need help with 3 Smart Card keys, 2 of which don't work
    By vikingshelmut in forum CX-9 Audio
    Last Post: 11-28-2009, 11:24 PM
  2. Replacement Smart Key.
    By Murphcoair in forum CX-9 Audio
    Last Post: 11-02-2009, 07:40 PM
  3. Looking for BROKEN CX-9 smart card
    By jdoering in forum CX-9 Audio
    Last Post: 07-21-2009, 02:53 PM
  4. Power seats: Smart Card
    By nyc1dxo in forum CX-9 Audio
    Last Post: 06-17-2009, 07:44 PM
  5. Smart card Vs FOB
    By 206B3 in forum Mazda3 Audio
    Last Post: 04-24-2008, 09:56 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
