where did you get the fuel rail adapter and it comes with a gasket correct?... that is what i need... please if you can remember where you got it point me in that direction
So with the aftermarket FPRs did you guys just bypass the stock pressure release valve? IIRC, the stock FPR is a 1:1 rising rate, there's just a pressure release valve upstream of it that bleeds off excessive pressure.
So how do these things work? The one mspHtown posted says 30-70 psi. So does that mean at most it can supply only 70 psi of fuel pressure or is that 70 psi above stock? I'm just curious because the stock fuel pressure is supposed to be 39-45 psi primed (not running). My primed fuel pressure is 39 psi and while running it's about 36 psi at idle. So a 1:1 FPR would increase the fuel pressure by one psi per psi of boost? 46 psi seems kind of low for 10 psi of boost...
damn I can't find that adapter anywhere. Your right mbxmotorsports.net doest work either
check this thread out.
