Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Page 1 of 44 12311 ... LastLast
Results 1 to 15 of 646
Thread: Mazdaspeed6 Clutch Fix TSB
  1. #1
    goes to eleven chuyler1's Avatar
    Car Audio & Southern New England Moderator
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,309
    UPDATE:
    This thread was started back in May of 2007. Keep that in mind as you read it. Very few owners received the full repairs of this TSB back then and dealerships and Mazda today are rarely performing the repair, especially if your vehicle's clutch has passed the 12,000 mile warranty period. Owners who are having trouble with their high mileage clutch should read How-To: MS6 Clutch adjustment. Also note that even with the repair the clutch will never be feather light or forgiving. It remains heavy and touchy even with the Type-A repairs and drivers used to other clutches (your friends, your wife) may still have trouble until they become acclimated to it. The repair only addressed the non-linear snap-like feeling the clutch had as you lifted up on it.
    TSB: 05-003/07
    2006 - 2007 MAZDASPEED6 - CLUTCH PEDAL IS DIFFICULT TO OPERATE
    APPLICABLE MODEL(S)/VINS
    2006 - 2007 Mazdaspeed6 vehicles with VINs lower than JM1GG****7*107613
    DESCRIPTION
    When releasing the clutch, the height of the pedal where the clutch starts to engage is higher than other vehicles making a smooth engagement difficult. Higher pedal pressure is required to depress the clutch pedal at the point of clutch engagement.
    The following mass-production changes have taken place:
    Feb. 21, 2006 - Improved clutch pedal characteristics.
    May 26, 2006 - Improved clutch cover release load characteristic.
    July 1, 2006 - Improved clutch disc cushion deflection.
    Type A Vehicle
    (VINs from JM1GG******100001 - 106359)
    Type B Vehicle
    (VINs from JM1GG******106360 - 107613)
    Clutch Pedal Type: "Pre-Modified"
    Clutch Pedal Type: "Modified"
    REPAIR PROCEDURE
    1. Verify customer concern that clutch pedal is awkward or difficult to operate.
    2. Determine if vehicle is Type A or Type B:
    If Type A vehicle (with Pre-Modified Clutch Pedal): Replace clutch pedal, clutch cover, and clutch disc assemblies with modified parts according to Workshop Manual (section 05-10 CLUTCH PEDAL REMOVAL/INSTALLATION A26MX-R).
    If Type B vehicle (with Modified Clutch Pedal): Replace clutch cover and clutch disc assemblies with modified parts according to Workshop Manual (section 05-10 CLUTCH UNIT REMOVAL/INSTALLATION A26MX-R).
    3. Verify repair.
    PART(S) INFORMATION
    CAUTION: * The modified Clutch Cover Assembly and Clutch Disc Assembly must be replaced as a set.Part Number
    Description
    Qty.
    GP4L-41-300A
    Clutch Pedal Assembly
    1
    L304-16-410A
    *Clutch Cover Assembly
    1
    L304-16-460B
    *Clutch Disc Assembly
    1
    P017-27-421A
    Driveshaft Retaining
    2
    T060-26-169A
    Tie-Rod Nut Lock
    2
    GJ6A-33-023C
    Lower Arm Bush (Front)
    2
    GJ6A-33-024C
    Lower Arm Bush (Rear)
    2
    A601-17-117
    Drain and Filler Plug Seal
    2
    L3A1-40-581
    Seal Ring
    1
    LN01-27-3A2
    Ring "O"
    1
    LN01-27-3A3
    Oil Seal
    1
    WARRANTY INFORMATION
    NOTE:
    This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
    Additional diagnostic time cannot be claimed for this repair.
  2. #2
    Registered Member MUSOM's Avatar
    2006 MazdaSpeed 6 GT
    Join Date
    Feb 2007
    Location
    Huntington, WV
    Posts
    256
    I'm gonna try this exact thing tomorrow when I go to the dealership. thanks for the info.
    2006 MazdaSpeed 6 Grand Touring Pearl White Mica.
  3. #3
    Mazdaspeed Approved X 3 Rainman's Avatar
    2006 Black Mica MS6 GT + 2007 MS3 (2003.5 Yellow MSP = retired)
    Join Date
    Mar 2004
    Location
    Ottawa
    Posts
    1,881
    Now that we are all used the clutch....LOL!
    R
    Current Rides:
    10 WRX STi
    07 Red MS3
    04 Honda CBR600rr
    Previous Rides:
    06 Black MS6 (sad to see it go!)
    03.5 Blazin' Yellow MSP
    00 Protege SE
    91 Yamaha FZR 600
    Other non-Mazda crap
  4. #4
    MSP 2003.5 Yellow Retired Rican219's Avatar
    MazdaSpeed 6
    Join Date
    Mar 2003
    Location
    Suwanee, Ga
    Posts
    511
    They said the parts aren't available yet for this fix. That sux!
    www.myspace.com/rican219
    MODS:
    TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk
  5. #5
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,309
    They? Did you speak with your dealer?
  6. #6
    Mazda 6 MPS (Speed6) Templar's Avatar
    Mazda 6 MPS (Speed6), DP, Exhaust, Intake.
    Join Date
    Apr 2007
    Location
    Iceland
    Posts
    40
    Any one have a rattle in the frame surrounding the handle to open the front doors. I get a little rattle when there's a lot of base going on.
    On another note, how do I check my car's VIN number for that clutch issue?
    Thanks.
    Simon
  7. #7
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,309
    Its along your windshield on the driver's side I think...the same place it is on all cars. It is also on your vehicle registration and insurance statement and every piece of paperwork you got from the dealer when you purchased the car.
  8. #8
    Registered Member
    Join Date
    Dec 2006
    Posts
    17
    I spoke to my dealer earlier today. They stated that I need to bring the car in for it to be evaluated. Based on the evaluation, they'll decide if the TSB needs to be done or not.
    Next time I have it in the dealership I'll have the evaluation done. But according to the service rep, the evaluation takes hours and I'll need to leave the car with them for a full day.
    I've not done the clutch modification and still find that my clutching isn't as smooth as I would like it to be. But, maybe my expectations are too high or I'm just a crappy driver. Hopefully they'll decide that this needs to be done. But, I'm not overly optimisitc that they'll deem the TSB as being needed.
  9. #9
    Join Date
    Feb 2007
    Location
    Huntington, WV
    Posts
    256
    how do you know this?
    Quote Originally Posted by chuyler1
  10. #10
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,309
    Make sure you un-do the clutch mod before you take it in. That will better your chances. If they try to deny it, explain to them that Mazda has already admitted a defect, hence the TSB, and since they will get reimbursed by Mazda for the repair there is no reason for them to deny the claim. If they still deny it, take it to another dealership.
  11. #11
    MazdaSpeed 6
    Join Date
    Mar 2003
    Location
    Suwanee, Ga
    Posts
    511
    Yes 2 Dealerships one of them said they had not heard of it till I asked then they pulled it up. They both said I would have to go through an evaluation. Does that mean I need to put my car back to stock? If so that is going to suck!
  12. #12
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,309
    I would say, put the clutch back to stock and take it in. Just explain that you have had a problem with the clutch since you got the car and driving in stop-and-go traffic is very difficult. If dealership 1 tries to deny the claim based on other mods and you can't convince them otherwise...remove the mods and go to dealership 2.
  13. #13
    Registered Member Rawyzf's Avatar
    Donated: $30
    2011 Mazda CX-9 GT AWD & 2015 Chevrolet Silverado Z71
    Join Date
    Nov 2002
    Location
    Blaine, Minnesota
    Posts
    3,434
    Quote Originally Posted by Rainman
    R
    LOL...no kidding. I wonder if they will give any grief since I already adjusted it a little on my own?
    2011 Mazda CX-9 Grand Touring AWD - Brilliant Black Clearcoat
    MODS: K&N Air Filter, WeatherTech Floor Liners, R1 Concepts Premium Slotted Rotors, Posi Quiet Ceramic Pads
    Winter Wheels: - 18" Drag DR-38 (18x8 +35 Offset) with Bridgestone Blizzak DM-V1 245/60/18 - Click for Pics
    Summer Wheels: - 20" Lorenzo WL32 (20x8.5 +35 Offset) with Cooper Discoverer H/T Plus 275/45/20 - Click for Pics
    2015 Chevrolet Silverado Z71 4x4 Crew Cab Short Box - Deep Ocean Blue Metallic
    2008 Saab 9-7x Aero - Carbon Black Metallic - SOLD Mar, 2015
    2009 Pontiac G8 GT - Magnetic Grey Metallic - SOLD Dec, 2013
    2006 Mazda Mazdaspeed6 - Whitewater Pearl - SOLD Jun, 2009
    2003.5 Mazda Mazdaspeed Protege - Blazing Yellow - SOLD Jun, 2006
  14. #14
    AWD...say Bye Bye
    Retired AMM..Got Bingo?
    Titanium MS6
    Join Date
    Feb 2004
    Location
    Tampa, FL
    Posts
    1,342
    sweetness, so we get a brand new clutch out of it.... But I'm concerned on the exact type of changes that will take place. If they simply "soften" the clutch engagement, it just means more lag in power transfer and the potential of the clutch to wear out faster... ie it would only be able to support 300hp instead of say 350hp...
    Now offers 2 versions of our ever popular AFC
    *Version I...the original...
    *Version II...includes 4 logging channels in addition to the ones included with version I. The most noteable beign the ability to log wideband o2 signals on the same graph with rpm, boost, etc...
    In addition we do offer our AFC version I & II with built in timing retard for those of you wanting a little added safety at high boost/rpm levels...This is only offered on a limited individual basis.
  15. #15
    Donated: $30
    Join Date
    Nov 2002
    Location
    Blaine, Minnesota
    Posts
    3,434
    Quote Originally Posted by DSMConvert
    Is that really the whole clutch pretty much?
    My VIN ends with 104414, so that puts me in the Type A area.
Similar Threads
  1. MazdaSpeed6 Clutch Burned Out
    By caputo27 in forum Mazda6 Engine & Transmission
    Last Post: 11-20-2009, 05:24 PM
  2. Clutch Kit for Mazdaspeed6
    By kalonov in forum Mazda6 Engine & Transmission
    Last Post: 08-06-2009, 11:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
