Okay, I have been getting random PMs on how-to clean up the motor a little more. This is a little how-to on how I did it. If something goes wrong and you ruin something, don't yell at me please. (enguard)
This was over a year ago. The pictures are old, but the idea is still there. Where you bolt or ground new wires is up to you and that is the hardest part of this task. There are tons of places to re-ground things, but you just need to find them.
Also, now would be a good time to do any motor work:
Installing ground wires
Installing motor mounts
Doing the coolant by-pass throttle body mod
Installing turbo... (first)
Thing you will need:
- Electrical tape
- Scissors and a razor
- Extra wire loom
- Extra Vacuum lines (if you want to buy aftermarket ones like hosetechniques, now is the time)
- Various wrenches and tools
- 2-3 Days time
- Extra vehicle incase something does go wrong
- A strong back. Believe me, I was aching after a while
- Extra bolts or screws
- Vacuum plugs (incase you want to remove the cruise control)
First, remove all unnecessary items from the motor:
- Battery
- Battery tray
- Intake piping to the throttle body
- Strut tower bar
- Anything else you can see that might get in the way
Next, I undid the wire loom near the transmission
From here, you can re-tape the wires and section them off better and hide them under where the battery tray will go. Also, there are tons of ground wires near the engine block and radiator hose. You can connect that to one grounding point instead of 3 or 4 different ones.
Much cleaner!
The first time I did this, I was lazy to take the tray out, but I redid this again later.
Well, not much has changed except the wires on the transmission look cleaner, but lets take this a step further...
- Electrical tape
- Extra wire loom
- 2-3 Days time
- Battery
- Battery tray
- Strut tower bar
Much cleaner!
