hiboost coolant temp sensor
defchino
02 P5-T
hello again...
First of many install questions from this hiboost newb:
Does anyone have a pic of the new style coolant temp sensor location. I have the old instructions with no pics and can't figure out where it goes.
Thanks
The coolant sensor housing goes in the upper radiator hose. Cut the hose about 3 inches from the outlet neck (head side), and place the housing between the 2 hose ends.
Juan
defchino said:
hello again...
Thanks
hey, HiBoost can I get a picture of the sensor, and do you sell the sensor housing alone, I got a water temp gauge but I don't know where to put the sensor.
Here you go...
This is from my install.. Keep in mind I have a different turbo setup:
where did you get the sensor housing? that's exactly what I am looking for.
No problem. I forgot, if you need the new instructions, just PM me your e-mail address. I have it in (mswerd) format with pictures.
Linux, can you post a pic of the air temp sensor as well? I'm just curious, I still have to order the two sensors and I want to see one.
Here ya go..
Thanks man, that thing is tiny. You've been a big help by the way. I appreciate it. If you don't remember me I'm the one with the girlfriend that was screaming at Hiperf at the Austin meet. lol
Trust me, I will never forget that...lol
Juan,
You may want to look at making the wires to the coolant sensor at least 3 inches longer. We had to lengthen them on install.
Linux, Maybe you went a different route in the wiring. That was designed using a car a meassured. I have installed some cars with the same length and that is long enough.
Yes. It is a good idea to use a new hose as it tends to harden with use.
Juan
