If I had a traditional air cooler, then yes, rear would be the exhaust. But because I'm water cooled, you want that fan blowing in (according to everything I've read).The rear should be exhausting though...you want that heat exiting. This should not make things dusty.
You're working against the intake of the front that way, but you are probably getting slightly cooler air to the radiator, but not sure it's much. Personally I'd flip it, but that's just me.If I had a traditional air cooler, then yes, rear would be the exhaust. But because I'm water cooled, you want that fan blowing in (according to everything I've read).
Besides, because of the case design, there's plenty of extra exhaust from all of the vents above the card slots.
I knew you'd agree with me.Personally I'd flip it, but that's just me.
I'm good, just not been good at keeping up with most of my forums lately.You OK, bro? Where you been? LOL I was waiting for you to reply because...
It'll be fine, it certainly doesn't hurt anything. My thinking here is even if exhausting the back somehow does get MORE dust inside your case.... people like us occasionally check our cases to make sure they don't need a quick cleaning.
#Geek
Well, my 1080TI I think was dying. I got this screen a few times...
It's a stock EVGA SC2.Is the card overclocked? Because this can happen when pushing it too far. Dial it back to stock frequencies, and this may go away.
What your screen is doing right now is called artifacting. The only way a repaste/repad is going to maybe fix that is if the source of the problem is overheating. But if the source of the problem is overheating, then that damage could be cumulative over time. I don't suppose you ever tried any utilities like MSI Afterburner to see what your temps were under full gaming load? If it's not an overheating problem then the GPU is 100% dying. As long as you are selling that as a dying card or for parts only (and price reflects that), then that shouldn't be a problem. I wouldn't try to sell that for whatever working used 1080 Ti's are going for.Well, my 1080TI I think was dying. I got this screen a few times...
Ss reluctantly, I replaced it with a 4060Ti. It uses a TON less power, and benchmarks out a hair better. Here is my original system benchmark as set up in 2017, then with my 1080Ti in 2019, and today, my 4060Ti.
2017
2019
2023
I purchased the 4060Ti in hopes of maybe a small performance bump, but mainly because it was $400 and would run MUCH cooler and on less power than my failing 1080Ti. What impresses me most is that the 4060Ti is a VERY new card, and NVIDIA is treating it as mid-tier, and the 1080Ti still hangs right there with it pretty much, even though it's half a decade older.
Before I pulled the 1080Ti, I ran the benchmark on Ghost Recon: Breakpoint with it. Everything maxxed out at 1440p:
Then I ran the 4060Ti, same:
You can be impressed by 2018 technology holding up super well to 2023 technology, or you can be impressed that after half a decade of COVID inflation, you can get about the same performance for 1/3 the price burning 1/2-2/3 the electricity.
PS: The 1080Ti is up for sale, with the full disclosure that I DO NOT GUARANTEE IT TO WORK. I DID provide the above benchmark minutes before it was pulled, though. I have been told that if you add thermal paste/replace it, it could fix this. It provides the messed up frozen screen/system initially pictured after gaming for a while and tabbing in/out of game. Price is obviously negotiable and I am open to offers. Again, this card is guaranteed to HAVE A PROBLEM. The severity of which, I am ignorant of and just detailed above. If you take a brick out of the bag, that's on you, but I've been transparent about it and no takesie backsies.
Precision Boost Overdrive. Allows you to go beyond default voltage values and boost the frequency for longer. Should be able to adjust the settings for it in the BIOS.PBO?
PBO might give you better single core scores due to higher single core boosts, but the best scores for CB R23 multi-core will come from just doing the highest all-core OC you can get (limit being your cooling). That's how I got 24k on my 5900X while PBO+CO was at best giving me 22-23k.I did a small refresh on my PC last week. I upgraded my Ryzen 3600 to a 5700, and I bumped my RAM from 32 GB to 64 GB with matching model numbers. 3 years old and still running strong.
Most annoying thing was my DisplayPort cable magically failed during the install. I plugged everything in and the computer wouldn’t post. VGA error. I was like you’ve got to be kidding me. I updated the BIOS and everything, what the hell could be wrong? Pulled the cable after reseating the GPU and passed post. Still couldn’t get a picture after several reboots and trying HDMI, and by some magic it finally providing video via HdMI.
I must be doing something wrong with the PBO and curve optimizer though. I tried multiple settings to overclock and I was actually getting worse Cinebench scores. After a few hours I gave up and reverted settings back to default in BIOS. Just running with that instead, no big deal.
