- Plano, Texas, USA
Standard disclaimer applies: This write-up describes how I modified the front turn signal bulb for US/NA version CX-5 only with LED Lightings. Other models may vary, your experience may vary. This is simply a chronicle of how I completed this task. If you choose to do the same, the responsibility for your actions lie with you alone.
Since there is no good solution so far for LED turn-signals without creating hyper-flash unless you're willing to add serial resistors, and no one seems to be able to find the flasher relay, here is one simple mod you can do so that you no longer have "ugly" amber parking lights (in some people's opinion) in the night. The white LED DRLs serve as the parking/side-marker lights well and they'll look exactly the same as a Euro CX-5! They do look cleaner with front amber parking/side-marker lights disabled but that is not the reason I did this mod. I like front amber turn signal which looks more distinctive in the dark with bright-off-bright-off pattern when front amber parking light is disabled, instead of bright-dim-bright-dim pattern when parking light is on. In fact, this is mandatory in Europe as you can't have front parking lights and turn signals at the same location for safety reason. The same for DRLs as you'll notice European cars will turn off DRL on the same side when the turn signal is on. These're all safety regulations in EU.
On CX-5 with LED lightings we have LED DRLs wrapping around to corners, they can serve as not only the parking lights but also the US-only side-markers too. We still have amber side marker reflector hence this mod is totally legal with US front side-marker requirements. In fact, the old CX-9's and some of new Mazda3's have similar setup - the amber turn signals are independent from front parking lights. The old CX-9 even keeps the "city lights" in high-beam reflectors only seen in Europe which serve as front parking lights.
Here are Euro version CX-5 I saw in Taipei with LED headlights without front amber parking lights, side-markers and side amber reflectors:
Here are my LED headlights without front amber parking lights and side markers:
On 2016 CX-5 with LED lightings, the front turn-signal/parking/side-marker lights use 7444NA amber dual-filament incandescent bulb. The rear turn-signal lights use 7440NA amber single-filament incandescent bulb. Be aware that the spec in our owner's manual for rear turn signal lights is wrong as it says 7443NA; and 7443 is a dual-filament bulb!
I started with getting some cheap Wagner 7440NA's as the base of all 744X bulbs looks the same. But I couldn't plug the 7440NA into the front turn-signal/parking/side-marker bulb socket. After further inspection, I found 7444NA socket has additional tabs, which prevent 7440NA bulb to be fully seated. Now I had to modify the 7444NA to make it becoming a single-filament bulb.
7444NA is pretty new and it's hard to find. You can only find unknown brand 7444NA at Amazon. Dealer price is outrageous and it requires special order. I then found the Philips 7444NA at local PepBoys. I simply cut the wire contact for parking/side-marker at the bulb base with electrical wire cutter. Now I could plug in the modified single-filament 7444NA bulb which only works for turn signal.
Those 744X series bulbs are very cleverly designed. They can be single or dual filament without worrying the orientation. You can plug them in either way and they'll work. You can take the 7440NA and compare, cutting two wire contacts on 7444NA, pointed by blue arrow in picture, which don't exist on 7440NA. Or you can trace the wire contacts to thinner filament with less wattage which located at front of the two filaments in the bulb, and cut these two. Or you can try to tape over one of the wire contacts you believe they are the two to cut, plug in and try it out before you actually cut them. Cutting one of two wire contacts is sufficient but I cut both anyway.
Make sure to follow the instruction on page 6-48 of Owner's Manual for how to remove front turn-signal/parking/side-marker light bulb.
For halogen headlights, or any non-LED DRL setups on CX-5, the front turn-signal/parking/side-marker lights use 1157NA amber dual-filament incandescent bulb. The only way to disable the parking/side-marker filament without cutting factory wiring harness, is to tape over the round contact at the base of the bulb. You won't have any lighting serves as parking lights and side markers because the DRLs are in the high-beam. This is something I definitely won't do if I don't have LED DRLs.
