Well I have got some work done on the car yesterday. I got the drivers door bottom sanded and painted. First I ground down the rust on the bottom, then sealed with rust converter, then etch primer then filler. And yesterday I got it sanded smooth and painted. Looks great.
Next I got the rear end links replaced. One was broke clean off. I had to cut them off.
I also got the windows tinted. I did it myself with pre cut window tint from http://www.precutautotint.com
All the windows went on nicely, I messed up the rear one. I just didn't use enough water/soap solution. I should have had my wife help with spraying but I didn't. Oh well. Live and learn. I just wanted to show you all the good and bad.
Lastly I did get two more coats of filler in the rusty area. I am just doing light coats. Enjoy some of the photos.
After first coat of filler
sanded and 2nd coat, and sanded again. I am thinking it will take 2 or 3 more light coats to get it all smooth.
Window tint. I took off the door panels, it makes it much easier.
Drivers door bottom repair.
