What have you done to your Mazda5 today?
Finally installed some MazdaSpeed3 wheels!
Next up is an HID kit!
From me! They look good.
Thanks again! I really like the new look and I'm surprised that the ride quality hasnt changed much even with the loss of sidewall coming from a 16' wheel.
Now I want springs, spoiler, sideskirt, wind visors, tint, and HIDs to finish up the looks department!
Got a present from CorkSport today
Very nice! However unless you have a 1st generation Mazda5 (2006-2010) that nameplate is the wrong one for our 2nd generation Mazda5s (2012-2015). I have been searching the correct PREMACY nameplate for a while to no luck. The second gen nameplate is all caps and in a different font.
D'oh you're right!
Did your -5 come with the fog lights or were they an after market ad-on? If you did it yourself, was the wiring in place (plug & play) or did you have to run the wires from the fuse yourself?
Oil change and transmission drain+fill at 68k miles for $180 at dealership. Expensive but new fluid makes such a difference in shift quality. The 1-2 shift is so much smoother now. Been doing this drain+fill every 20k since new.
Just out curiosities sake, why did you end up getting a Mazda brand audio cable? Usually things like that cost more.
Replaced my ravaged Michelin Premacy MXV 215-45-17 tires with Kumho Ecsta 4x 215-50-17, she looks a little better and should ride a lot smoother. The Michelins were very very good in all conditions but i should have my head examined for going with a 45 series tire on this car, replaced three tires due to impact damage. Of course the dead struts (since replaced) maybe had a LOT to do with that.... :/
205 50 is the stock size.. 215 45 would have been the correct size to be closer to the factory overall diameter. The 50 series sidewall should def make it a lil bit more comfy though
I run 225/45/17 on my 2012. That is the same overall Diameter as the 205/50/17. It rides pretty well on stock suspension. The biggest detractor is the fact that my 17x7.5 inch rims with fatter tires weigh about 6 lbs. more than stock.
I was thinking on running either 225/45/17 or 235/45/17 on my new 17x8 wheel. What do you guys think would be best? Oh and this would be riding on H&R springs.
I think it depends on the offset of your 17x8 inch rims. Keep in mind the stock rims are 17x6.5 with +52mm offset.
Latest posts
