I replaced my ABS sensors so I actually have a speedometer and power steering again.
I'm thinking I might try just swapping in the old front bump stops to the rear and see how the car rides.
The Bilsteins have an internal front bump stop and an external rear. Not sure how/if you could change it. I guess if you disassembled the body, you could get to it.. Not something I'm interested in trying. If/when I send them out for a revalve, I'll look into it further.I know the front bump stops aren't the right size for the rear, but I figure it will be a decent test of ride. I'm really anxious about cutting up the stock bump stops in case I need to revert to stock. When you guys take the rear shocks off do you jack up the car at all or just unbolt it as the car sits?
If anything I doubt buying new rear bump stops would be that expensive if you really needed to.
I recall CS saying that fatcat motorsports would be able to source a new set of bumpstops compatible for our cars.
I spoke with them a long while back and they mentioned that they could do something for the 2. We never pursued it though.
-Derrick
SUCCESS! I shoehorned the stock front bump stops into the rear! Post some pics later, I need to get back to work.
Awesome! How did it affect the ride?
