So as suggested I am putting this into the How-To section. This is a very cheap and easily sourced alternative to the E-Spec Wiper Arm for the Sedans.
Here Are the switches in question.
Benefits:
Adjustable Speed Intermittent Wiper Mode to replace our one speed.
Parts Needed:
New or Used Wiper Switch From a 2002-2005 Mazda6(maybe later years too, make sure it looks like the pictured one below)
Tools Needed:
1/4" Drive Ratchet
1/4" Drive 3" Extension
1/4" Drive 10mm Socket
3/8" Drive Ratchet
3/8" Drive 3" and 6" Extensions
3/8" Drive 13/16 Socket
Phillips Screw Drivers
Pre-Install:
Make sure that you unplug the battery before starting. Also, make sure you steering wheel is entirely straight(this will help later)
Warning:
This install involves removing the air-bag which could be potentially dangerous, unplugging the battery is a must before starting. As always do this at your own risk.
Clock Spring Warning:
Make sure that the clock spring is centered. It should be able to rotate 3 full turns in either direction. This is important, if you are not centered then you risk damaging the clock spring, which means no power to horn, cruise control, or your airbag, so take extra care making sure it is right.
Before
1. Remove the two 10mm bolts that hold the Air bag in place.
2. Pull airbag out and unplug it.
3. Unplug the horn wire from the clock spring
4. Remove the Single 13/16" Nut Holding the steering wheel in place, then remove steering wheel.
5. Remove Cover Under the Column (3 Screws)
6. Remove the Column Top Cover(un-clip from bottom cover)
7. Remove Clock Spring(3 Screws):
8. Remove the White Plastic Wiper and Headlight Switch Mount(3 Screws)
9. Remove these two screws on the Wiper Switch to detach it from the mounting bracket by sliding it away from the bracket.
Comparison of the switches
Pins Comparison
10. Install Switch into Mounting Bracket(2 screws)
11. Install Mounting Bracket and Clock Spring, Plug in the wiper switch and headlight switch plugs.
All Done
Video Coming Soon....
Benefits:
Parts Needed:
Tools Needed:
1/4" Drive Ratchet
3/8" Drive Ratchet
Pre-Install:
Warning:
Before
Pins Comparison
All Done
