marc_bachand
- Protege5-mazdaspeed miata
just buy front and back racing beat sway bar, do i need someting special ( link, bushing, ... ) to put them on my Protege 5 ( gt ) 2003
yup. bushings, endlinks, maybe the rear subframe, and LOTS of time because the front bar is a bee-otch to remove and replace.
He doesn't need a subframe but does need the AWR brackets that are meant for the P5. I used those along with ES bushings/brackets and it's all peachy.
No, I used the ES 20mm bushings with the brackets they came with.
Does the ES have a 20mm bar on the front?
ES = Energy Suspension
I only have a rear MSP sway bar.
the Protege ES has a 21 or 22mm front bar. with the 20mm rear from the MP3/MSP, the car has a nice balance.
Install the rear bar and forget about the front. Just the rear bar give the car (at least the sedans) as really nice balance. Get the longer MSP end links or the bar will flip-flop on you. If you come across the AXR Clunk-Fix brackets, those will help the bar work more effectively and eliminate the clunking you'll get from the MSP bar.
the front bar is 24mm and the back bar is 20mm, this is the AWR bracket for the back that you suggest ( http://www.awrracing.com/store/product_info.php?products_id=472 ) and probablie this ( http://www.awrracing.com/store/product_info.php?products_id=253 ) and for end links, just regular MSP or get the adjustable.
for the front, bushings-brackets, end links..., what do you suggest. i am more i plus and play kind of persone ( for my MSM is all FLYINGMIATA, 241WHP )
Having waited more than a year to install my front sway bar due to many people claiming it increases understeer, I can tell you now that I wouldn't listen to a single one of them. The MP3/MSP comes with both RB bars, and it is noticeably flatter around corners than the P5 without any extra understeer. If you are that concerned, then I suggest you install the AXR brackets (which will drastically increase the effectiveness of the rear bar) and also install the front bar. This is how my car is setup and I love it.
An added bonus of the AXR is that you don't have to deal with any of the bracket adapter bulls*** that you need otherwise. The AXR kit comes with everything needed.
For the front, I just used the stock horseshoe brackets and bushings, though I had to dremal out the bushings a bit to get the larger bar in them. Overall, my P5 is incredibly balanced and feels great. Turns on a dime with little body roll. Oh- and don't do either bar until you upgrade to Tokico Blues or risk busting an endlink tab off.
You sure the MSP endlinks are longer?? I don't understand why they would be longer...
You sure that's not a front vs. rear endlink?
Shorter suspension geometry on the MSP would dictate that a longer endlink would be completely counter productive, so I don't get why the MSP would have a longer endlink...
I think the subframe is the same. Or at least doesn't cause a problem.
I'm pretty convinced that ppl who complain about understeer with the RB front swaybar don't know how to drive a fwd car... (2thumbs)
