- SS MS3 GT
Alright.. did it last night. HOLY s***... wasnt that bad, just sucked. Now.. for the boost guage.
lmao. its a pita, you gotta undo the clips and move the wires out of the way. Then dislocate your wrist to unscrew the map. When ure done dont forget to snap your wrist back into place(humpleg)
lol come here buy pizza and beer an ill do it for you.
If you live in the Southeast, I'll take you up on that offer. Pizza, hell, I'll buy a good steak to make sure this gets done right. I'll actually turn the wrenches (should I say scrape the knuckles?), you just supervise and make sure I don't hook something up backwards and blow up the engine.
where in the southeast?
Im in charlotte. Just finished this yesterday...
Forge MBC.... PG fuel pump... BOOST CUT DEFENDER on order laloosh your gonna be my new best friend!
Hey guys, who is using the forge MBC? With the softest spring on the lowest setting, im getting WAY too much boost... like 25+ psi kinda too much boost.
any help? I know I have the lines hooked up right.
Compressor housing line to the bottom port of the MBC and side port of the MBC to the wastegate? That's the way it should be. And the second port on the T built into the cap of the wastegate will need to be blocked off, if that leaks you will get too much boost.
