No problems at all. I told them that I had tightened the nut and they were cool with that. Got a loaner (bottom line 3) with 6 miles on it. It took them two days because they had to order the part. My car came back about 10 lbs lighter (they washed it!). Clunk gone.mcopare said:Hey Rotus....clunk is back...taking it to the dealer on Monday. Did they give you a hard time about anything?
Rotus8 said:I have had my speed for about a month and have been hearing a clunking noise sometimes from the rear over bumps. I found the jack could move around but I fixed that and the clunk was still there. So I finally jacked it up and crawled underneath today to find the bolt on the stabilizer (anti-roll) bar right side link was completely loose! The nut was half way off the threads, I am surprised it didn't come all the way off - probably would have in a few more miles.
My manual says it should be torqued to 40 ft-lbs, so I try to tighten it and the nut won't tighten up. The threads on the stud are boogered up from banging around in the hole in the stabilizer bar. So I removed the link and had to repair the threads with a thread die. It's all back together now so I think it's cool, I will know for sure next time I drive it up a bumpy road.
Moral of the story - don't ignore clunks from your suspension; get it checked out before it boogers up the threads, or something worse.
whitey4311 said:Mine makes some sounds but I think its mianly the tight suspension that you are hearing and for me most of it was the foam in the hatch that holds the jack handle. It was flopping up and down making noise but I tend to only hear any noice when I hit cracks or bumps but not at any other time like through dips ect.
i went in for mine too. this should be a TSB.
my bolt actually stripped and the swaylink busted.
