SocialStealth
- 2002 Mazda Protege ES, 120k miles
When I first turn the fan speed up to 4, there is a slight sound, sort of like a hum. Any idea what it could be? It just recently started happening. It only occurs on setting 4, and only for the first few minutes, when the fan first starts up.
at 40mph +, I've noticed a considerable amount of increased vibrations.
I'm not having any idle issues, and the vibrations aren't there at high RPM's, just at 40 mph +.
If it were motor mounts, I would assume the vibrating would act up at high RPMS, not high mph's, right?
It feels sort of like a flat tire, but I checked and all the tires have 31 psi of air.
I did recently have a tire patched at pepboys, they took the tire off to do so. I'm hoping they didn't put it on wrong and forget to tighten up any bolts... they did forget to replace the cap on the air nozzle...
Any idea what the vibrating could be?
I also suspect my endlinks to be bad, but I don't think that would cause this problem...
