Jackie chan
- Pro5
Hey guys
On the lower timing cover there are marks that correspond to the notch on the outside of the crank pulley.
You know,
---10------T
I I I I I I I I I I I
Anyways, My cams are perfectly aligned and the crank is very close to TDC, However it is not perfect.
I am two notches to the right of the "T"
---10------T
---------------I----This is here my crankshaft is right now
Is this close enough, or do I have to tear it all down again.
If I do have to take it off again, what is the best way to keep the Crank at TDC
You know,
---10------T
---10------T
